Click to visit BT.com
BT.com Checkout Wishlist
Your basket is empty
Devolo dLAN® 500 WiFi Homeplug
At Last !!! - Wi-Fi Anywhere !!!
Standard delivery Delivered within 3-5 working days
39 in stock
£45.99
dLAN 500 WiFi technology combines the latest technology and unobtrusive design with the best Internet connection.
As a Powerline adapter, the dLAN 500 WiFi uses internal power lines as a long cable, thereby bringing the Internet to any room. The integrated wireless LAN also provides complete Internet coverage to every nook and cranny.
Smartphones, tablets and laptops have full-strength coverage right from the start without any problems.
An additional terminal device can be connected at any time (such as a Smart TV or game console) using the additional fast Ethernet connection. Now, smartphones, tablets and laptops are automatically connected to the Internet - the best Wi-Fi reception in any room or floor automatically! And the compact and unobtrusive design can be integrated into any residential interior without looking out of place.
The dLAN 500 WiFi from devolo brings the future to your home.
Devolo dLAN 500 WiFi - bridge - 802.11b/g/n - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
Frequency Band
2.4 GHz
Data Transfer Rate
500 Mbps
Network / Transport Protocol
CSMA/CA
Auto-uplink (auto MDI/MDI-X), MAC address filtering, Wi-Fi Protected Setup (WPS)
IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, HomePlug AV, IEEE 1901
AC 230V ( 50 Hz )
6.8 cm x 4.1 cm x 6.8 cm
Linux, Apple MacOS X, Android, Apple iOS, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
United Kingdom
3 years warranty
Bridge
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
500 Mbps
Max Range Open Space
300 m
CSMA/CA
Encryption Algorithm
WPA, WPA2, 128-bit AES, WEP
Status Indicators
WLAN, link/activity
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, OFDM , 1024 QAM, 4096 QAM
LAN : 1 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug AV , Antenna : 1 x
Internal power supply
AC 230V ( 50 Hz )
5 Watt
1 x network cable
United Kingdom
6.8 cm
4.1 cm
6.8 cm
3 years warranty
Service & Support Details
Limited warranty - 3 years
10 - 90% (non-condensing)
Packaged Quantity: 1
Speed: 500Mbps
Connectivity: Wired
Connectivity: Wireless
Brand: Devolo
Price Range Inc VAT: 0 - 50
