Jump in the action with the modern S2240L 21.5" monitor, offering ultra-wide viewing, a virtually borderless screen and image enhance feature. Images come alive with color-boosting image enhance, ultra-wide viewing and Full HD resolution in a 16:9 widescreen format. It helps connect to a laptop or desktop with VGA connectivity allowing exploring a world of HD entertainment options with an HDMI port. Creative projects, movies and games appear expansive on this 21.5" screen with an almost-invisible bezel.
The S2240L monitor offers a pristine finish, premier craftsmanship and a streamlined cable design. Savor razor-sharp detail in games, movies and photos with the color-boosting image enhance feature. Vivid clarity shines with a mega-dynamic contrast ratio of 8000000:1 and an 82-percent color gamut. It features Dell display manager helps keep you productive with fast access to software such as Auto Mode, which enables you to select your preferred color mode for each application. In addition to being ENERGY STAR, the S2240L monitor features arsenic-free glass and a mercury-free LED panel. Reduce power consumption by dimming the monitor or by putting it into sleep mode by enabling PowerNap.
Product Description | Dell S2240L - LED monitor - Full HD (1080p) - 21.5" | Device Type | LED-backlit LCD monitor - 21.5" | Energy Class | Class A+ | Energy Consumption per Year | 23 kWh | Power Consumption (On mode) | 16 W | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.248 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 8000000:1 (dynamic) | Response Time | 7 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 82% | Input Connectors | HDMI, VGA | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) - with stand | 49.91 cm x 17.58 cm x 38.02 cm | Weight | 3.69 kg | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | ENERGY STAR Qualified EPEAT Silver | Manufacturer Warranty | 3-year warranty (United States, Latin America - 1 year) |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 21.5" |
Panel Type | IPS |
Vertical Refresh Rate | 76 Hz |
Horizontal Refresh Rate | 83 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Dimensions (WxDxH) | 49.91 cm x 17.58 cm x 38.02 cm - with stand |
Weight | 3.69 kg |
Connectivity | |
Interfaces | VGA , HDMI |
Mechanical | |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), tilt adjustment |
Included Accessories | Stand |
Cables Included | 1 x VGA cable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 18 Watt |
Power Consumption Sleep | 0.5 Watt |
On / Off Switch | No |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 49.91 cm - depth: 17.58 cm - height: 38.02 cm - weight: 3.69 kg , Without stand - width: 49.91 cm - depth: 3.78 cm - height: 29.76 cm - weight: 2.6 kg |
Sustainability Information | |
EPEAT Compliant | EPEAT Silver |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years , United States: limited warranty - 1 year , Latin America: limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
