ITEM | QTY | PRICE |
LG 32" HD Ready HDR Smart LED TV
4 | £716.00 |
Stay focused on a 23.8-inch QHD monitor optimized to deliver high performance details and clarity.
Product Description | Dell P2423D - LED monitor - QHD - 23.8" - TAA Compliant | Device Type | LED-backlit LCD monitor - 23.8" | Energy Class | Class E | Power Consumption (On mode) | 16 W | Features | USB 3.2 Gen 1 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | QHD 2560 x 1440 at 60 Hz | Pixel Pitch | 0.2058 mm | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 1000:1 (dynamic) | Response Time | 5 ms (fast), 8 ms (normal) | Colour Support | 16.7 million colours | Colour Gamut | 99% sRGB | Input Connectors | HDMI, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 100-240 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 53.78 cm x 17.957 cm x 49.611 cm | Weight | 5.45 kg | TAA Compliant | Yes | Environmental Standards | TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified | Compliant Standards | RoHS, NFPA 99, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free, Mercury-free | Bundled Services | 3 years Advanced Exchange Service and Limited Hardware Warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Built-in Devices | USB 3.2 Gen 1 hub |
Panel Type | IPS |
Pixel Per Inch | 123 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED edgelight backlight |
Features | Arsenic-free glass |
Colour | Black |
Dimensions (WxDxH) | 53.78 cm x 17.957 cm x 49.611 cm - with stand |
Weight | 5.45 kg |
Connectivity | |
Interfaces | DisplayPort 1.2 (HDCP 1.4) , HDMI (HDCP 1.4) , USB 3.2 Gen 1 upstream , 4 x USB 3.2 Gen 1 downstream |
Mechanical | |
Tilt Angle | -5/+21 |
Swivel Angle | 90 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support |
Cables Included | 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 cable - USB Type A to B |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 16 kWh/1000h |
Power Consumption (Max) | 55 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption Sleep | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
On / Off Switch | Yes |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 53.78 cm - depth: 17.957 cm - height: 49.611 cm - weight: 5.45 kg , Without stand - weight: 3.44 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 7.44 kg |
Sustainability Information | |
TCO Certified | TCO Certified Edge Displays, TCO Certified Displays 9 |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
