Click to visit BT.com
D-Link IP Camera Wireless N HD Megapixel Network Camera
D-Link D-Link IP Camera Wireless N HD Megapixel Network Camera
Usually dispatched within 3 working days
Quicklinx: 7S3YWS00
Mfr#: DCS-2130/B
£130.58
The DCS-2130 is a unique and versatile surveillance solution for your home or small office. Unlike a traditional webcam, the DCS-2130 is a complete system with a built-in CPU and web server that transmits high quality video images for security and surveillance. Simple installation and an intuitive web-based interface offer easy integration with your Ethernet or 802.11n wireless network. The DCS-2130 also comes with remote monitoring and motion detection features for a complete and cost-effective home security solution.
The DCS-2130 includes 802.11n wireless for fast and easy integration into your existing network environment. Wireless N allows you to stream highquality video to remote sites and mobile devices. A Site Survey feature also allows you to view and connect to nearby wireless networks with ease. The DCS-2130 also includes a standard Ethernet port for connections to traditional wired networks.
The ePTZ feature allows users to select a target region for close-up viewing simply by clicking on the video feed displayed within their browser. ePTZ makes use of the camera's megapixel resolution to survey a large area effortlessly. Since ePTZ requires no moving parts, there is no need to worry about the camera having mechanical failures.
This network camera supports the Universal Plug-n-Play feature, which allows computers running on Windows XP/Vista/7 to automatically recognize the camera and add it to the network. Sign up with one of the free Dynamic DNS services available on the web to assign a name and domain to the camera (e.g. mycamera.dlinkddns.com), and remotely access the camera without having to remember your IP address. You may also view up to 32 cameras from a central location using the included D-ViewCam software. D-ViewCam has a robust set of features including automated e-mail alerts which can instantly inform administrators of suspicious or unusual activities.
The Open Network Video Interface Forum (ONVIF) is standards relating to open IP video networking. The DCS-2130 is ONVIF compliant and therefore interoperable with other manufacturer's products on the same network such as cameras, storage systems, video analytics products and Video Management Systems.
The included D-Link D-ViewCam (DCS-100) is a sophisticated video management software which enables you to manage up to 32 network cameras, set e-mail alert notifications, create recording schedules, and trigger motion detection to record directly to your hard drive or network folder. D-ViewCam also allows you to upload a floor plan of your premises, and create a realistic layout according to the locations of your cameras, further simplifying the management process.
D-Link SECURICAM DCS-2130 HD Cube Network Camera - network camera
Network camera - fixed
Wired, wireless
12.9 cm x 8.2 cm x 8.9 cm
0.69 kg
United Kingdom
Camera
Colour - Day&Night
Optical Sensor Type
CMOS - 1/4"
Minimum Illumination
1 lux - F2.0
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Control Interface
Alarm Inputs Qty : 1 , Alarm Outputs Qty : 1
Digital Zoom
10
Audio Support
Yes : two-way audio capability, built-in microphone
DC 5 V
Motion sensor, date/time stamp, sharpness control, brightness control, contrast control, e-mail alerts, ONVIF support, microSD card slot, Privacy Mask Function, text stamp
1 x network cable - external
UNIX, Linux, Apple MacOS X 10.3 or later, Microsoft Windows 2000/XP/Vista/7
Stand
Environmental Parameters (operating)
0 °C ... 40 °C ; 20 - 80% (non-condensing) relative humidity
Network camera
Wired, wireless
12.9 cm
8.2 cm
8.9 cm
0.69 kg
United Kingdom
Camera
Colour - Day&Night - fixed
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1280 x 800
Digital Zoom
10
1 lux - F2.0
Video Capture
160 x 120 @ 30 fps , 320 x 240 @ 30 fps , 640 x 480 @ 30 fps , 1280 x 1024 @ 30 fps , 1280 x 720 @ 30 fps
Audio Support
RAM
128 MB
Flash Memory
32 MB
Image Sensor
CMOS 1/4"
Lens Construction
Angular Field of View (degree)
- 57.8 x 37.8
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n - DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, RTCP, PPPoE, IGMP, Samba, 3GPP/ISMA
Alarm Inputs Qty
1
Alarm Outputs Qty
1
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x audio - line-out - mini-phone 3.5mm
Stand
FCC Class B certified, C-Tick
Power Requirements
DC 5 V
Power adapter - external AC 120/230 V ( 50 - 60 Hz ) 2.5 Watt
Software Included
D-ViewCam 2.0
Operating Temperature
0 °C ... 40 °C
Relative Humidity (operating)
feature value
Brand D-Link
Price Range Inc VAT 100 - 150
