Click to visit BT.com
Crucial 4GBKIT (2 x 2GB) 240-Pin DDR2 667MHz PC2-5300 NON ECC CL5
Crucial Crucial 4GBKIT (2 x 2GB) 240-Pin DDR2 667MHz PC2-5300 NON ECC CL5
15 In stock
Quicklinx: 4Q84WS00
Mfr#: CT2KIT25664AA667
£42.99
A dual inline memory module (DIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The gold pins on the bottom of the DIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a DIMM are not connected to each other.
240-pin DIMMs are used to provide DDR2 SDRAM memory for desktop computers. DDR2 is a leading-edge generation of memory with an improved architecture that allows it to transmit data very fast.
Image gallery
Select any thumbnail below to view a larger image.
Crucial memory - 4 GB : 2 x 2 GB - DIMM 240-pin - DDR2
Storage Capacity
4 GB : 2 x 2 GB
Upgrade Type
System specific
Sun SESX2B3Z, Sun T6340-X-22, IBM 8233, Apple MA248G/A, Sun SESX2B2Z, Sun X4203AF, Sun X5279A-Z, Sun SESX2B1Z, Kingston KTA-G5533/4G, Kingston KTM-JS22K2/4G, Kingston KTS-SESK2/4G, Kingston KTS-SESVK2/4G, Kingston KTS5277K2/4G, Kingston KVR400D2N3K2/4G, Kingston KVR667D2N5K2/4G
DDR2 SDRAM
DIMM 240-pin
Memory Speed
667 MHz ( PC2-5300 )
Data Integrity Check
Non-ECC
Latency Timings
CL5
Unbuffered
Supply Voltage
1.8 V
Intel Desktop Board D955XBK
Storage Capacity
4 GB : 2 x 2 GB
Upgrade Type
System specific
DRAM
DDR2 SDRAM
DIMM 240-pin
Memory Speed
Latency Timings
CL5
Non-ECC
RAM Features
Unbuffered
Module Configuration
256 x 64
Supply Voltage
1.8 V
Compatible Slots
2 x memory - DIMM 240-pin
feature value
Capacity 4GB
Connection DIMM 240-pin
Speed 667MHz
Data Integrity Non-ECC
Registered/Buffered Unbuffered
CAS Latency CL5
Standard PC2-5300
Brand Crucial
Stock Status In Stock
Price Range Inc VAT 0 - 50
