Click to visit BT.com
Crucial 2GB 800MHz DDR2 PC2-6400
Crucial Crucial 2GB 800MHz DDR2 PC2-6400
59 in stock
Quicklinx: 55XMWS00
Mfr#: CT25664AA800
£19.41 inc VAT
A dual inline memory module (DIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The gold pins on the bottom of the DIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a DIMM are not connected to each other.
240-pin DIMMs are used to provide DDR2 SDRAM memory for desktop computers. DDR2 is a leading-edge generation of memory with an improved architecture that allows it to transmit data very fast.
Each 240-pin DIMM provides a 64-bit data path (72-bit for ECC or registered or Fully Buffered modules). (The Ballistix™ and Ballistix Tracer™ high-performance memory do not come in 72-bit or registered modules.)
Standard DDR2 240-pin DIMMs are available in DDR2 PC2-3200 SDRAM, DDR2 PC2-4200 SDRAM, DDR2 PC2-5300 SDRAM, and PC2-6400 SDRAM.
To use DDR2 memory, your system motherboard must have 240-pin DIMM slots and a DDR2-enabled chipset. A DDR2 SDRAM DIMM will not fit into a standard SDRAM DIMM socket or a DDR DIMM socket.
The number of black components on a 240-pin DIMM can vary, but it always has 120 pins on the front and 120 pins on the back, for a total of 240. 240-pin DIMMs are approximately 5.25 inches long and 1.18 inches high, though the heights can vary. While 240-pin DDR2 DIMMs, 184-pin DDR DIMMs, and 168-pin DIMMs are approximately the same size, 240-pin DIMMs and 184-pin DIMMs have only one notch within the row of pins. The notch in a 240-pin DDR2 DIMM is closer toward the center of the module.
Image gallery
Select any thumbnail below to view a larger image.
Crucial memory - 2 GB - DIMM 240-pin - DDR2
Storage Capacity
2 GB
Upgrade Type
Generic
DELL A2149882, DELL A2055829, DELL A1669629, DELL A2810658, DELL A2810656, HP 457624-001, Kingston KTH-XW4400C6/2G, DELL A2887205, HP NQ605AT, DELL A1229322, HP AH060AA, IBM 41U2978, IBM 41X1081, HP AH060AT, DELL A1302689, DELL A1302686, DELL A1545199, DELL A1545200, DELL A1545335, DELL A1544901, DELL A1545367, DELL A3198146, HP 5189-2180, HP KC923-69001, DELL A0735489, DELL A0735492, DELL A0735493, DELL A0743585, DELL A0743586, DELL A0764429, DELL A1189543, DELL A1229318, DELL A1229319, DELL A1229320, DELL A1229324, DELL A1229325, DELL A1312839, Crucial MT16HTF25664AZ-800H1, DELL A1302690, DELL A1370435, DELL A1763798, DELL A1763802, DELL A2050435, DELL A2129718, DELL A2149876, DELL A2149880, DELL A2315684, DELL A2463645, DELL A2686137, DELL A2686139, DELL A2686141, DELL A2686143, DELL A2686145, DELL A2686147, HP AU741AA#ABA, Crucial CT16HTF25664AY-800J3A, Kingston D25664G60, Kingston KFJ2890/2G, Kingston KTD-DM8400C/2G, Kingston KTD-DM8400C6/2G, Kingston KTD-INSP6000C/2G, Kingston KTL2975C6/2G, Kingston KVR800D2N5/2G, Kingston KVR800D2N6/2G, Crucial MT16HTF25664AY-800E1, Crucial MT16HTF25664AY-800G1
DDR2 SDRAM
DIMM 240-pin
Memory Speed
800 MHz ( PC2-6400 )
Data Integrity Check
Non-ECC
Latency Timings
CL6
Unbuffered
Supply Voltage
1.8 V
Lead Plating
Gold
ASRock ALiveNF5, ALiveNF5SLI, P45TurboTwins2000, X48; ASUS P5K, P5N, P5Q, P5QC; BFG nForce 590, nForce 680, NVIDIA nForce 680; Biostar NF520, NF520 A2; EliteGroup G31; eVGA e-7150/630; Foxconn A79, A7GM, ELA, P45; Gigabyte GA-MA770, MA78, MA790, X38; Intel Desktop Board DG31, DP35, DQ35; MSI K9A2
Storage Capacity
2 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Memory Speed
Latency Timings
CL6
Non-ECC
RAM Features
Unbuffered
Module Configuration
256 x 64
Supply Voltage
1.8 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
ABIT AB9 Pro, AW8D, AW9D, AW9D-MAX , ASRock 775Twins-HDTV R2.0, ALiveNF4G-DVI, ALiveNF5-eSATA2+ R3.0, ALiveNF5SLI-1394, ALiveSATA2-GLAN, AM2NF3-VSTA, AM2NF4G-SATA2, AM2NF6G-VISTA, AM2V890-VSTA, AM2XLI-eSATA2, P45TurboTwins2000, P4Twins-HDTV, X48TurboTwins-WiFi , ASUS M2N, M2N DH, M2N32 WS Professional Main Station Series, M2N32-SLI Deluxe AiLifestyle Series, M2N32-SLI Deluxe/Wireless Edition AiLifestyle Series, M2N4-SLI, M2NBP-VM CSM, M2N-MX, M2NPV-VM, M2N-SLI Deluxe, M2N-VM DH Digital Home Series, M2R32-MVP, P5B-VM AiLifestyle Series, P5K-E AiLifestyle Series, P5K-E/WIFI-AP AiLifestyle Series, P5N-D, P5Q, P5Q Deluxe, P5Q Premium, P5QC, P5VD2-X, P5W DH Deluxe Digital Home Series , BFG nForce 590 SLI, nForce 680i SLI, NVIDIA nForce 680i LT SLI, NVIDIA nForce 680i SLI , Biostar NF520 A2, NF520-A2G , EliteGroup 761GXM-M V1.0, G31T-M (V1.0) , EPoX EP-MF4 Ultra, EP-MF4-J, EP-MF570 SLI, EP-MGF6100-M , eVGA e-7150/630i , Foxconn 975X7AA-8EKRS2H, A79A-S, A7GM-S, C51XEM2AA-8EKRS2H, ELA, P45A, P45A-S, P4M800P7MA-ERS2H, P9657AA-8EKRS2H, P9657AA-8KS2H , Gigabyte GA-8I955X PRO, GA-8N775, GA-965G-DS4, GA-965P-DQ6, GA-G1975X-C, GA-M51GM-S2G, GA-M55plus-S3G, GA-M55SLI-S4, GA-M57SLI-S4, GA-M59SLI-S4, GA-M59SLI-S5, GA-MA770-S3, GA-MA78GM-S2H, GA-MA790FX-DQ6, GA-X38-DS5 , Intel Desktop Board DG31PR Classic Series, DG965WH, DP35DP Media Series, DP965LT, DQ35JO Executive Series , MSI 945GT Speedster-A4R, 975X Platinum PowerUp Edition, K9A Platinum, K9A2 CF-F, K9A2 Platinum, K9N Diamond, K9N Neo-F, K9N Platinum, K9N SLI Platinum, K9N Ultra, K9NGM2, K9NGM-L, K9SGM, K9VGM, P965 Neo, P965 Platinum , SUPERMICRO PDSBA+
feature value
Capacity 2GB
Connection DIMM 240-pin
Speed 800MHz
Data Integrity Non-ECC
Registered/Buffered Unbuffered
CAS Latency CL6
Standard PC2-6400
Brand Crucial
Stock Status In Stock
Price Range Inc VAT 0 - 50
My BT Shop Basket
your basket is empty
Add an item by clicking
Mini basket dummy button. This button serves as indication only
next to the product of your choice.
BT Phone Offers
Find an Easy to use phone
Check out our range of Which Best Buy Phones - Click Here
New BT Home Hub 3
BT Phone Finder
Brand new range of BT Baby Monitors
