Click to visit BT.com
Corsair VS2GBKIT400C3 PC3200 2x1GB CAS3
Corsair Corsair VS2GBKIT400C3 PC3200 2x1GB CAS3
20 in stock
Quicklinx: 3PCNWS00
Mfr#: VS2GBKIT400C3
£38.04 inc VAT
Customer rating
4.0*
View reviews
Corsair Value Select line provides quality, tested, compatible desktop memory at competitive prices. The Value Select line is qualified for major current desktop systems.
Image gallery
Select any thumbnail below to view a larger image.
Customer reviews read all 2 customer reviews
Write a review for the Corsair VS2GBKIT400C3 PC3200 2x1GB CAS3 here!
Quailty stuff
Reviewed by Alan Jennings. Review Posted 13/01/2006
Good memory and very good value for money. Had a few teething probelms due to old memory i was also using on the motherboard, some corsair 512mb sticks, just took them out and had the 2 1gb running at dual speed so worked a treat.
  • Overall 4*
  • Ease of use 5*
  • Value for money 5*
Good value memory
Reviewed by Paul. Review Posted 08/01/2007
Bought these to replace 2x 512mb PC2700 in my ASUS 78NX-X mb. Runs at 3 3 3 8 @ 200mhz out of the box, swiftly oc to 2.5 3 3 7 and you can't really complain about that for the price point.
If you are system builder on a budget these are great; if you are a serious OC'er you may want to look at the TWINX series for only a few bucks more
  • Overall 4*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Corsair Value Select memory - 2 GB : 2 x 1 GB - DIMM 184-PIN - DDR
Storage Capacity
2 GB : 2 x 1 GB
Upgrade Type
Generic
DDR SDRAM
DIMM 184-PIN
Memory Speed
400 MHz ( PC3200 )
Data Integrity Check
Non-ECC
Latency Timings
CL3
Unbuffered
Storage Capacity
2 GB : 2 x 1 GB
Upgrade Type
Generic
DRAM
DDR SDRAM
DIMM 184-PIN
Memory Speed
400 MHz ( PC3200 )
Latency Timings
CL3
Non-ECC
RAM Features
Unbuffered
Module Configuration
128 x 64
Compatible Slots
2 x memory - DIMM 184-PIN
feature value
Capacity 2GB
Connection DIMM 184-PIN
Speed 400MHz
Data Integrity Non-ECC
Registered/Buffered Unbuffered
CAS Latency CL3
Standard PC3200
Brand Corsair
Stock Status In Stock
Price Range Inc VAT 0 - 50
My BT Shop Basket
your basket is empty
Add an item by clicking
Mini basket dummy button. This button serves as indication only
next to the product of your choice.
BT Phone Offers
Recently viewed
Find an Easy to use phone
Check out our range of Which Best Buy Phones - Click Here
New BT Home Hub 3
BT Phone Finder
Brand new range of BT Baby Monitors
