Corsair Flash Voyager - USB flash drive - 4 GB - USB 2.0
Customer rating
View reviews
Corsair Flash Voyager USB drives are rugged, stylish, compact, reliable, and exceptionally fast, making them ideal for transporting MP3s, digital images, presentations and more. With data transfer rates up to 19Mb/sec, Flash Voyager drives are fully Hi-Speed USB 2.0 compliant, and are backward compatible with USB 1.1. They support Plug and Play with most operating systems. Their durable rubber casing is easy to grip and water resistant.
Durable -- Corsair's proprietary all-rubber housing is extremely durable, water resistant and drop-tested for worry-free transport of your valuable data
Shock Proof -- Solid state storage makes Flash Voyager drives virtual shock proof
Convenient -- Just plug it and go! No special cables, no power adapters needed
Compatible -- Works with Windows, Windows 7, Mac OS X and even Linux without drivers
Backed by Corsair -- A respected name with a passion for great service and support
Select any thumbnail below to view a larger image.
Write a review for the Corsair Flash Voyager - USB flash drive - 4 GB - USB 2.0 here!
Works well, easy to use and robust casing makes it a must for business
My 2GB version was destroyed, my 4GB drive stolen yet I haven't had a more reliable and resilient flash drive EVER. Superb brand, make, quality, never hesitate to buy one.
Can't wait for the 8GB+ versions...
Absolutely brilliant must have product if your into IT as it enable quick transfer of whole directory structures to be moved
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
