BT.com
Wishlist
Corsair 16GB (2 x 8GB) Vengeance Pro Red DDR3 2400MHz CL10
Delivery
Standard Due date unavailable
Corsair Vengeance Pro Series memory modules are designed for overclocking on the latest 3rd and 4th generation Intel® Core™ platforms, with eight-layer PCBs and ICs specially selected for performance potential. The aluminum heat spreaders provide superior temperature management and have the aggressive look you want in your gaming rig. XMP 1.3 profiles allow for automatic, reliable overclocking.
They're available in multiple colours to let you match your Vengeance Pro memory to your system's color scheme. As a bonus, they're priced to deliver class-leading value, so you'll have more room left in your system build budget.
Corsair Vengeance Pro Series - DDR3 - 16 GB : 2 x 8 GB - DIMM 240-pin
RAM memory
16 GB : 2 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz ( PC3-19200 )
Latency Timings
CL10 ( 10-12-12-31 )
Aluminium heatsink, dual channel, Vengeance heatspreader, Intel Extreme Memory Profiles (XMP 1.3) , unbuffered
Voltage
1.65 V
16 GB : 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
Non-ECC
Voltage
1.65 V
Compatible Slots
2 x memory - DIMM 240-pin
Scroll to top
