Click to visit BT.com
Cisco ESW 520 48 Port 10/100 Switch+4Gig/SFP
Cisco Cisco ESW 520 48 Port 10/100 Switch+4Gig/SFP
2 In stock
Quicklinx: 65BQG600
Mfr#: ESW-520-48-K9
£437.98
The Cisco ESW 500 series, part of the Cisco Small Business Pro series, is a group of managed Ethernet switches that provide wire-speed Fast Ethernet and Gigabit Ethernet connectivity, integrated security, quality of service (QoS), and Power over Ethernet (PoE) to support all of your business network needs. These switches integrate easily with Cisco Small Business Pro products as well as the Cisco Smart Business Communications System to provide a complete data, voice, video, and wireless networking solution for your business. With the Cisco ESW 500 series, you can take advantage of a proven network solution and a broad portfolio of high-performance, easy-to-manage switches that are designed and priced for small businesses.
The Cisco ESW 500 series switches provide security, management, and other capabilities far beyond what unmanaged or "smart" switches can provide, without requiring you to configure features you don't need. The switches were designed to be part of the complete line of Small Business Pro networking and voice communications products that work together as part of proven, fully integrated, easy-to-use small business solution.
Image gallery
Select any thumbnail below to view a larger image.
Cisco Small Business Pro ESW-520-48 - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed
Enclosure Type
Rack-mountable - 1U
Ports
48 x 10/100 + 2 x SFP + 2 x 10/100/1000
Performance
Switching capacity : 17.6 Gbps , Forwarding performance (64-byte packet size) : 13 Mpps
MAC Address Table Size
8000 entries
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS
Flow control, Layer 2 switching, DHCP support, auto-negotiation, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, traffic shaping, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
AC 120/230 V ( 50/60 Hz )
44 cm x 37.4 cm x 4.4 cm
2.19 kg
5 years warranty
Enclosure Type
Rack-mountable - 1U
Ports
Performance
8000 entries
Encryption Algorithm
MD5, SSL
Authentication Method
RADIUS
RAM
128 MB
Flash Memory
32 MB
Status Indicators
Port transmission speed, power, link/activity, fan
48 x 10Base-T/100Base-TX - RJ-45 , 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Serial : 1 x console - 9 pin DIN , 2 x SFP (mini-GBIC)
Power supply - internal
44 cm
37.4 cm
4.4 cm
2.19 kg
1 x serial cable
Mounting Kit
Included
MTBF
155,680 hour(s)
C-Tick, UL 60950, CSA C22.2, FCC CFR47 Part 15
5 years warranty
Service & Support Details
Limited warranty - replacement - 5 years - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 90 days
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
10 - 95% (non-condensing)
feature value
Type Fast Ethernet
Ports 48
Data Transfer Rate 100Mbps
Managed Yes
Brand Cisco
Stock Status In Stock
Price Range Inc VAT 300 - 500
