Select any thumbnail below to view a larger image.
Cisco Small Business MFELX1 - SFP (mini-GBIC) transceiver module
SFP (mini-GBIC) transceiver module - LC single mode
Enclosure Type
Plug-in module
0.9 cm x 5.6 cm x 1.3 cm
18 g
Cabling Type
100Base-LX
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
Fast Ethernet
Max Transfer Distance
10 km
FCC Class B certified, UL, cUL, ICES-003, CB, FCC Part 15
Enclosure Type
Plug-in module
0.9 cm
5.6 cm
1.3 cm
18 g
Wired
Cabling Type
100Base-LX
Fast Ethernet
Data Transfer Rate
100 Mbps
Optical Wave Length
1310 nm
10 km
1 x network - Ethernet 100Base-LX - LC single mode x 2
Compatible Slots
1 x SFP (mini-GBIC)
70 °C
10 - 85%
