With the EOS 60D DSLR, Canon gives the photo enthusiast a powerful tool fostering creativity, with better image quality, more advanced features and automatic and in-camera technologies for ease-of-use. It features an improved APS-C sized 18.0 megapixel CMOS sensor for tremendous images, DIGIC 4 Image Processor for finer detail and excellent color reproduction, and improved ISO capabilities from 100 - 6400 (expandable to 12800) for uncompromised shooting even in the dimmest situations. The Multi-control Dial enables users to conveniently operate menus and enter settings with a simple touch. The EOS 60D also features an EOS first Vari-angle 3.0-inch Clear View LCD (1,040,000 dots) monitor for easy low- or high-angle viewing. An improved viewfinder, a number of in-camera creative options and filters, plus HDMI output for viewing images on an HDTV all make the EOS 60D invaluable for the evolving photographer. With continuously curved surfaces, user-friendliness and exuding solidity and refinement, the EOS 60D is true digital inspiration!
Product Description | Canon EOS 60D - digital camera EF-S 18-135mm IS lens | Product Type | Digital camera - 1080p - SLR with Live View mode, movie recording | Lens Included | EF-S 18-135mm IS lens | Memory Card Slot | SD card | Image Processor | DIGIC 4 | Sensors | Digital level metre | Sensor Resolution | 18.0 Megapixel | Max Video Resolution | 1920 x 1080 | Lens System | Zoom lens - 7.5x zoom - 18 - 135 mm - f/3.5-5.6 Canon EF-S | Focus Adjustment | Automatic, manual | Min Focus Distance | 45 cm | Image Stabiliser | Optical | Camera Flash | Pop-up flash | Viewfinder | Optical - fixed eye-level pentaprism | Display | LCD display - 3" | Supported Battery | Li-ion rechargeable battery (included) | Interface | Composite video/audio, HDMI, USB 2.0 | Microsoft Certification | Compatible with Windows 7 | Dimensions (WxDxH) | 14.5 cm x 7.9 cm x 10.6 cm | Weight | 0.68 kg |
General | |
Optical Sensor Type | CMOS |
Total Pixels | 19,000,000 pixels |
Effective Sensor Resolution | 18,000,000 pixels |
Optical Sensor Size | APS-C (22.3 x 14.9 mm) |
Field of View Crop Factor | 1.6 |
ISO (Max) | 12800 |
Sensor Dust Reduction | Yes |
Sensor Features | EOS Integrated Cleaning System, Self Cleaning Sensor Unit |
Optical Zoom | 7.5x |
Face Detection | Yes |
Print Standard | Direct print, DPOF support, Exif Print support, PictBridge support |
Auto Focus | TTL contrast and phase detection |
Auto Focus Points (Zones) Qty | 9 |
Digital Video Format | MOV |
Image Recording Format | JPEG, RAW, RAW + JPEG |
Exposure & White Balance | |
Light Sensitivity | ISO auto, ISO 12800, ISO 100-6400 |
Exposure Metering | Evaluative, partial (6.5%), multi-segment, centre-weighted, spot |
Exposure Metering Zones | 63 |
Exposure Modes | Programme, bulb, automatic, manual, aperture-priority, shutter-priority, E-TTL II program flash |
Shooting Programs | Landscape, portrait mode, close-up, night portrait, sports mode |
Special Effects | Neutral, Custom Effect, Faithful, monochrome, landscape, portrait |
White Balance | Custom, automatic, presets |
White Balance Presets | Fluorescent, cloudy, tungsten light, Flash, daylight, shade |
Max Shutter Speed | 1/8000 sec |
Min Shutter Speed | 30 sec |
Exposure Compensation | ±5 EV range, in 1/2 or 1/3 EV steps |
Auto Exposure Bracketing | 3 steps in 1/2 or 1/3 EV steps |
White Balance Bracketing | Yes |
X-sync Speed | 1/250sec |
Exposure Range | EV 0-20 (ISO 100) |
Lens System | |
Type | Zoom lens - 7.5x zoom - 18 - 135 mm - f/3.5-5.6 Canon EF-S |
Focal Length Equivalent to 35mm Camera | 29 - 216mm |
Max View Angle | 74.3 degree(s) |
Zoom Adjustment | Manual |
Lens Construction | 12 groups / 16 elements |
Filter Size | 67 mm |
Lens Mounting Type | Canon EF/EF-S |
Features | UD glass, internal focusing system |
Camera Flash | |
Guide Number (m / ISO 100) | 13 |
Flash Modes | Fill-in mode, E-TTL, rear curtain sync, auto mode, flash OFF mode, red-eye reduction |
Red-Eye Reduction | Yes |
Features | AF illuminator, flash +/- compensation |
Additional Features | |
Continuous Shooting Speed | 3 frames per second, 5.3 frames per second |
Self-Timer Delay | 10 sec, 2sec |
Flash Terminal | Hot shoe |
Additional Features | RGB primary colour filter, digital noise reduction, depth-of-field preview button, camera orientation detection, histogram display, highlight tone priority, LCD live view mode, highlight point display, face detection, Auto Lighting Optimizer, in-camera RAW processing, peripheral illumination correction |
Viewfinder | |
Viewfinder Type | Optical - fixed eye-level pentaprism |
Optical Viewfinder Field Coverage | 96% |
Optical Viewfinder Magnification | 0.95x |
Optical Viewfinder Dioptric Correction Range | -3 to +1 |
Viewfinder Information | Shutter speed, AE lock, AF-in-focus, flash charge completion, red-eye reduction, aperture, white balance, battery status, high-speed sync indicator, flash compensation on/off, highlight tone priority, ISO sensitivity, memory card status, FE lock |
Display | |
Type | 3" LCD display |
Display Format | 1,040,000 pixels |
Display Form Factor | Rotating |
Display Features | Display brightness control |
Microphone | |
Microphone Operation Mode | Mono |
Connections | |
Connector Type | Composite video/audio output , USB , HDMI , Microphone |
Software | |
Software | Drivers & Utilities, Canon PhotoStitch, Canon ZoomBrowser EX, Canon ImageBrowser, Canon Remote Capture, Canon Digital Photo Professional |
Miscellaneous | |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Included Accessories | Battery charger, dust cap, body cap, lens cap, neck strap, USB cable, eyecup, audio / video cable |
Body Material | Aluminium, fibreglass-reinforced polycarbonate resin |
Battery | |
Battery Type | Canon LP-E6 Lithium Ion |
Details | Li-ion rechargeable battery (included) |
Memory / Storage | |
Supported Memory Cards | SD Memory Card, SDXC Memory Card, SDHC Memory Card |
Image Storage | RAW 5184 x 3456 , RAW 3888 x 2592 , RAW 2592 x 1728 , JPEG 5184 x 3456 , JPEG 3456 x 2304 , JPEG 2592 x 1728 , JPEG 1920 x 1280 , JPEG 720 x 480 , JPEG 4608 x 3456 , JPEG 3072 x 2304 , JPEG 2304 x 1728 , JPEG 1696 x 1280 , JPEG 640 x 480 , JPEG 5184 x 2912 , JPEG 3456 x 1944 , JPEG 2592 x 1456 , JPEG 1920 x 1080 , JPEG 720 x 400 , JPEG 3456 x 3456 , JPEG 2304 x 2304 , JPEG 1728 x 1728 , JPEG 1280 x 1280 , JPEG 480 x 480 |
Video Capture | MOV - 1920 x 1080 - 30 fps , MOV - 1920 x 1080 - 25 fps , MOV - 1920 x 1080 - 24 fps , MOV - 1280 x 720 - 60 fps , MOV - 1280 x 720 - 50 fps , MOV - 640 x 480 - 60 fps , MOV - 640 x 480 - 50 fps , MOV - 640 x 480 - 30 fps , MOV - 640 x 480 - 24 fps |
Dimensions & Weight | |
Width | 14.5 cm |
Depth | 7.9 cm |
Height | 10.6 cm |
Weight | 0.68 kg |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
