Click to visit BT.com
CablesToGo TruLink 1-Port 60 GHz WirelessHD HDMI Kit - Transmit Full 1080p HD Wirelessly!
CablesToGo CablesToGo TruLink 1-Port 60 GHz WirelessHD HDMI Kit - Transmit Full 1080p HD Wirelessly!
Quicklinx: 70F4G600
Mfr#: 89000
The TruLink 1-Port 60 GHz WirelessHD Kit enables high definition wireless transmission between your television and your HDMI components. Enjoy the full HD 1080p signal from your computer, Blu-ray™ player, set-top box, gaming console or other HDMI device to your HDMI-enabled television. The 60 GHz transmission capability means greater flexibility in your home theater setup by allowing you to place the in-room components up to 10 metres apart (longer distances may be supported depending upon the environment).*
This complete kit (which includes the wireless transmitter and wireless receiver) is ideal for situations where in-wall cabling is either not feasible (such as in plaster, brick or exterior walls) or not desired (such as in apartments or other rental properties). By offering true uncompressed audio/video transmission, the TruLink WirelessHD kit is a quick, convenient and reliable cable replacement. This plug-and-play solution requires no software, no drivers and no setup ? simply connect the receiver with the HDMI component and instantly transmit content to your television.
Convenient and reliable high performance! With its plug-and-play setup, this solution requires no drivers or software. The auto power function automatically turns off the attached component when the transimtter is turned off. The transmitter and receiver each have an on/off switch to conserve power when not in use, and both are wall-mountable.
Note: Although performance characteristics may exceed stated distance limitations depending upon the environment, we recommend, that per best practices, the transmitter and receiver should face each other within the same room, be located within 33 feet of each other, be placed at the same level (i.e. the transmitter should not be placed higher than the receiver), and be located in open spaces (i.e. not in a cabinet or enclosed shelf).
See How Wireless HDMI Can Work For You!
  • WirelessHD® 1.0 certified
  • Meets Digital Transmission Content Protection (DTCP) protocol
  • Compatible with other WiHD-enabled consumer electronics bearing the WiHD® logo
  • HDMI 1.3 compatible
  • FCC and CE approvals
  • 36 antenna array provides a strong wireless signal
  • Data transfer rates up to 4 Gbps
  • Supports true uncompressed 1080p @ 60 GHz resolution
  • Supports 7.1 channel surround sound
  • Available HDMI port on connected component
  • Available HDMI port on television/monitor
  • Color : Black
Image gallery
Select any thumbnail below to view a larger image.
Resources
The following resources are available for the CablesToGo TruLink 1-Port 60 GHz WirelessHD HDMI Kit - Transmit Full 1080p HD Wirelessly!
C2G TruLink 1-Port 60 GHz WirelessHD Kit - video/audio extender
Video/audio extender
Enclosure Type
External
Data Transfer Rate
4 Gbps
HDMI
Max Transfer Distance
10 m
WirelessHD 1.0 , FCC, RoHS
1 year warranty
Enclosure Type
External
Enclosure Colour
Wireless
HDMI
Data Transfer Rate
4 Gbps
Max Resolution
1080p @ 60 Hz
10 m
WirelessHD 1.0
2 x audio / video - HDMI - 19 pin HDMI Type A female
2 x HDMI cable - 1.2 m
FCC, RoHS
Power adapter - external
1 year warranty
Service & Support Details
Limited warranty - 1 year
