Click to visit BT.com
Buffalo AirStation NFINITI Wireless-N High Power Broadband Router
Buffalo Buffalo AirStation NFINITI Wireless-N High Power Broadband Router
2 In stock
Quicklinx: 7FWGG600
Mfr#: WHR-HP-G300N
£42.98
The AirStation™ High Power N300 Wireless Router WHR-HP-G300N is an ideal solution to connect your PCs and laptops wirelessly to the Internet. It is best suited for the home and small office environment. Is it great for streaming multimedia content, such as HD movies or music, lets you download images or send and receive email from multiple PCs simultaneously. With transfer rates up to 300 Mbps*, the WHR-HP-G300N is also ideal for upgrading your existing wireless network, providing greater speeds and coverage than Wireless-G.
Maximum Wireless Coverage with High Power Technology
Dead spots in your home or office can slow down your wireless access and even prevent you from getting online. Advanced High Power technology from Buffalo enhances signal strength and can almost double the range.
* Optimized antennas and tuned radios boost signal strength for maximum performance and range
* Adjustable high power antennas extend signal range to eliminate dead spots
* Stay connected from anywhere in your home or office
Enjoy outdoor living and stream your favorite tunes to your outdoor speakers using your AirPlay® supported device from the deck - it's in range.
Open Source DD-WRT Router
Leading open-source firmware equipped with robust and high-performance features for custom configuration.
* Intuitive interface helps you set up and connect in no time
* Customizable advanced features allow to optimize wireless performance, security and routing options
* Advanced features also include VPN endpoints, hot-spot sign in, VLAN and more
Faster Wireless Connectivity with Wireless N300
At speeds up to 300 Mbps*, wireless N300 provides a high speed wireless connection.
* Perfect for streaming HD movies, television shows, music and other multimedia content
* Multiple antennas and radios provide whole home or office coverage
Experience faster, uninterrupted playback when streaming from Netflix® or Hulu™ or gaming online with your Xbox® or PS3™.
Secure Guest Network
Keep your network secure and maintain data integrity with a secondary wireless network for guest use or additional wireless devices. Limit guests to Internet access only or connect your slower legacy devices on separate, dedicated network.
* Keep your personal data secure
* Configure device accessibility on the guest network
* Allow friends and family to use the internet without keeping your personal devices secure
Greater Coverage with Wireless Bridging (WDS)
Bridge and repeat using multiple units. Endlessly expand your wireless network to cover large areas and improve performance.
Buffalo AirStation wireless router - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Network / Transport Protocol
CSMA/CD
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g
( 50/60 Hz )
2 years warranty
Enclosure Type
Desktop
Wireless, wired
CSMA/CD
Power adapter - external
( 50/60 Hz )
2 years warranty
feature value
Type Wireless router
Standards Ethernet
Standards Fast Ethernet
Standards IEEE 802.11b
Standards IEEE 802.11g
Brand Buffalo
Stock Status In Stock
Price Range Inc VAT 0 - 50
