Click to visit BT.com
Buffalo 1TB DriveStation USB 2.0 Desktop Hard Drive
Buffalo Buffalo 1TB DriveStation USB 2.0 Desktop Hard Drive
151 In stock
Quicklinx: 7G8WG600
Mfr#: HD-LB1.0TU2-UK
£69.99
Buffalo's DriveStation USB 2.0 Hard Drive lets you store, backup, or easily transport various files, including huge multimedia files too large to fit on a USB key. Just plug it into your computer and it installs automatically with Windows 2000, XP, or OS-X computers. Fanless Heat Sink Chassis design lets the DriveStation run cool and quietly. The unique chassis design may be placed vertically or horizontally. With auto installation and SecureLockWare support, the DriveStation is a plug and play secure and reliable USB backup and storage solution.
Key Specifications
  • USB 2.0 Interface
  • Pre-formatted drive for immediate use
  • Easy set-up, no drivers required
  • Connects to USB on any PC or Mac
  • Connector Type: USB Type B
  • Data Transfer Rate Max: 480Mbps (USB 2.0 Mode)
  • Setup Utility OS Support: Windows®7 (32bit, 64bit), Windows® Vista™(32bit, 64bit), Windows® XP, Mac OS 10.4 or later
  • Dimensions (W x H x D) 38.7 X 122.6 X 189mm
  • Weight 950g
  • Operating Environment 5-35°C, 20-80% (non-condensing)
Image gallery
Select any thumbnail below to view a larger image.
Resources
The following resources are available for the Buffalo 1TB DriveStation USB 2.0 Desktop Hard Drive
Buffalo DriveStation hard drive - 1 TB - USB 2.0
Hard drive - external ( desktop )
1 TB
USB 2.0
Power Source
Included AC adapter
Enclosure Colour
Glossy black
3.9 cm x 18.9 cm x 12.3 cm
0.95 kg
United Kingdom
2 years warranty
1 TB
USB 2.0
Internal Drive Interface
Serial ATA
3.9 cm
18.9 cm
12.3 cm
0.95 kg
Performance
Max Data Transfer Rate
480 MB/s
Expansion & Connectivity
1 x USB 2.0 - mini-USB Type B
Power Source
Included AC adapter
Power supply
AC 120/230 V ( 50/60 Hz )
Power Consumption (Active)
12 Watt
Microsoft Windows XP, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits)
Enclosure Colour
Glossy black
United Kingdom
2 years warranty
Service & Support Details
5 °C
35 °C
20 - 80% (non-condensing)
feature value
Form Factor 3.5"
Capacity 1TB
Interface Hi-Speed USB
Brand Buffalo
Stock Status In Stock
Price Range Inc VAT 50 - 100
