The BT8500 comes with BT's unique Virtual Assistant, which means you'll never have to speak to another cold caller again:
Key Features
Even more advanced call blocking
Quality Built-in
Easy to use
Extra Answer Machine Features
Freedom to Move in Your House
Need a Phone in More Than One Room?
You can get our twin, trio or quad packs should you need additional handsets for other rooms. Whichever pack you buy you will only need one telephone socket in your home to work all the handsets.
What's in the (Recyclable) Box?
*You must subscribe to a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
Manufacturer Warranty | 1 Year Warranty |
The following resources are available for the BT8500 Premium Nuisance Call Blocker - Twin
