Works with any Broadband provider
BT's Wi-Fi Dongle 300 has been designed to work with any service provider to make sure everyone can make the most of their broadband around their home.
What does BT’s Wi-Fi Dongle 300 give you?
Bring wireless internet access to those laptops and computers that need a wire to connect to Broadband and enjoy the full broadband experience at home.
Easy set-up – get wireless in minutes!
Everyone loves to be online; and why should you settle for anything other than the complete broadband experience? With BT's Wi-Fi Dongle 300, connect your laptops and computers to the internet and get broadband wherever, however and whenever you like.
Simple to use
BT's Wi-Fi Dongle 300 is easy to use. Simply plug into a USB socket of your laptop or computer, follow the easy to use set-up guide and enjoy a great Wi-Fi experience in minutes.
Make the most of your Broadband
BT's Wi-Fi Dongle 300 enables you to make the most of your broadband by bringing wireless internet to a wired computer or laptop and getting online anywhere at home.
Got a Dual-Band router? Make the most of it
If you have a Dual-Band router, BT's Wi-Fi Dongle 600 would enable you to take advantage of your Dual-Band Wi-Fi. If not, why not upgrade your wi-fi with BT's Dual-Band Wi-Fi Kit 600? Take advantage of the improved speed and reliability on offer to deliver an unrivalled broadband experience.
The BT connectivity range
BT's Dual-Band Wi-Fi Extender 300 is just one part of BT's new connectivity range, which has been designed to solve all connectivity issues to ensure everyone makes the most of their broadband around their home. Other products include Broadband Extenders, Dual-Band upgrade kits, Wi-Fi Extenders and switches, ensuring all your major connectivity requirements are covered.
The following resources are available for the BT Wi-Fi Dongle 300
