Click to visit BT.com
BT.com
Wishlist
BT Voyager 1065 Wireless Laptop Adapter
Customer rating:4.0*
Quicklinx: 4D3DWS00
Mfr#: 015704
The BT Voyager Wireless Adapters are plug and play 802.11g wireless networking adapters, developed to enable connection to a wireless network or base station.
These Adapters allow you to connect your personal computer to the broadband Internet like any other ADSL modem without the use of cables between your computer and the ADSL socket. The BT Voyager 1065 Laptop adapters send and receive signals to and from your PC and wireless Router.
This gives you the wireless freedom to surf wherever you want in the home or office, and not be limited to where the ADSL socket is!
The Voyager 1065 is installed in a free PCMCIA slot in your laptop.
Key benefits
  • Share broadband connection
  • Surf away from your desk with a laptop
  • Use your computer where you want, not where the ADSL socket is
  • Connect your laptop to public WLAN hotspots
  • Easy to use and install
  • Product helpdesk support
  • Simple management software
  • Compatible with the BT Voyager 2110 and most other 802.11g devices (Sold separately)
  • Backward compatible with 802.11b
  • Comprehensive user guide and technical guide
  • Smart, slim product design
  • BT quality and reliability
  • Full CE approval
The BT Voyager 1065 Desktop pack contains...
  • BT Voyager 1065 Laptop Adapter
  • Quick Start Guide and CD
BT Voyager 1065 - network adapter
Network adapter
Plug-in module
Interface (Bus) Type
CardBus
5.4 cm x 11.9 cm x 1.1 cm
802.11b, 802.11g
Frequency Band
2.4 GHz
Microsoft Windows 98SE/2000/ME/XP
Network adapter
Plug-in module
CardBus
Wireless
802.11b, 802.11g
Frequency Band
2.4 GHz
Max Range Indoors
50 m
Max Range Open Space
250 m
Compatible Slots
1 x CardBus
Encryption Algorithm
128-bit WEP, WPA
Plug and Play
5.4 cm
11.9 cm
1.1 cm
55 °C
5 - 95%
Resources
The following resources are available for the BT Voyager 1065 Wireless Laptop Adapter
Customer reviews
Write a review for the BT Voyager 1065 Wireless Laptop Adapter here!
Brilliant!!
Reviewed by EmiLou. Review Posted 11/09/2009
Really quick, free delivery. Excellent value for money. Was up and running in less than 10 minutes!!
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Voyager 1065
Reviewed by James Delves. Review Posted 16/09/2008
Excellent product - no problem to install and speedy deilvery. Fantastic service.
  • Overall 5*
  • Ease of use 5*
BT Voyager 1065 Wireless laptop Adapter
Reviewed by Roy Rose. Review Posted 14/08/2008
Very simple and clear instructions to install this device, just load the CD on your computer, plug in the adapter when prompted, restart your computer, select the network to connect to and your done.
  • Overall 5*
  • Ease of use 5*
1055 and 1065 wireless adapters
Reviewed by a.simpson. Review Posted 20/08/2008
bought the two about 6 month ago still cant get them 2 work, bt say its the laptop but i have had it 2 3 shops and they say its a BT problem. i see they have dropped the price a good bit lately !!!!!
  • Overall 1*
  • Ease of use 1*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
