BT Mobile Broadband Pre-Pay
Customer rating
View reviews
The BT Mobile Broadband dongle is a small USB modem that plugs into your computer for Internet access at home and on the go.
It gives you Internet access at up to 7.2Mb depending on where you are; the USB modem will automatically connect via the HSDPA, 3G or GPRS network network - with 80% of the UK covered it'll ensure you get the best connection possible.
It comes with 1GB of usage will get you connected to the internet straight away.
With 1GB of usage you can download:
Or any combination - the above is only a guide and how you use it is up to you.
Select any thumbnail below to view a larger image.
Write a review for the BT Mobile Broadband Pre-Pay here!
After a rather dreadful experience with O2, The BT Mobile broadband product is a wonderful experience. O2 offer a hilarious product called "Pay and Go", which should really be called Pay & Pay & Pay etc - they expect you to buy £15 credit every month, whether you need it or not. I remember they had the same hairbrained scheme when 2G mobiles became "Pay as you Go" with all the other operators, and O2 insisting you add credit even if you don't need it. Sorry rant over - the BT Mobile product is not only much more flexible (It really is "Pay as you Go"), but unlike its O2 counterpart, it actually works too.
this is the best by far mobile broadband dongle i have used speed and connection are excellent , and now i can use it on my mac thanks to your recent link for the bt manager download provided by tim , and now its half price try it its good thanks bt for a great bit of kit even though been a long time coming for mac users its been worth the wait .
I am an exsisting option 3 customer & have just contacted customer services after having read all these reviews. Have re-newed my contract for another 18months which has included a free dongle with 1GB allowance per month.I have no intentions of leaving BT as have always found them an excellent ISP Also a reduction in my line rental..so cant be bad. Also have BT vision & got a reduced rate on my package. So give a call first before you moan.
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
