BT Inspire 1500 Cordless Phone with Answer Machine
Customer rating
View reviews
BT Inspire 1500 Cordless Phone with Answer Machine + Durable 5758 Telephone Cleaning Wipes - Box of 100
Stylish and contemporary cordless telephone with answering machine. Packed with useful features such as handsfree speaker and text messaging.
Select any thumbnail below to view a larger image.
The following resources are available for the BT Inspire 1500 Cordless Phone with Answer Machine
Write a review for the BT Inspire 1500 Cordless Phone with Answer Machine here!
This BT branded phone is solidly made and is comfortable to use. The handset is nicely finished, with both shiny and matte plastic panels. Call quality is fine. The phone is very similar to a basic mobile phone in terms of how to find and alter the settings, and has several ringtones to choose from, some even sound quite nice.
Initial setup is straightforward, however be sure to use the supplied telephone cable! I initially plugged our old telephone cable (which worked fine with our previous phone) into the back of this one, however the phone would not make or receive calls. It worked just fine as soon as I used the supplied cable though (which looked exactly the same as our old one).
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
