BT Hub Phone 2.1
Customer rating
View reviews
The New Hub Phone slots neatly into your BT Home Hub 2.0 and gives you UK Evening and Weekend calls at no extra cost - and cheap calls at other times via BT Broadband talk.
It is a fully featured handset which will operate anywhere within the range of your homehub.
** Handset must be registered to BT Home Hub 2.0 for all features to be accessible
Select any thumbnail below to view a larger image.
The following resources are available for the BT Hub Phone 2.1
Write a review for the BT Hub Phone 2.1 here!
MY HUB PHONE IS PLAYING UP. IT IS SEARCHING FOR HUB ALL TIME. TRIED CHANGING BATTERIES, RESETTING ETC TO NO AVAIL. PLEASE HELP - I NEED MY PHONE
works well with good range. gives extra phone when kids (or wife) are on the landline.
Well, i received mine as part of the Broadband option 3 package, and at first thought eh up! no sooner had i connected it directly to the Hub, as reviewer previously mentioned, it started to display the incorrect date and time, but after waiting a while (has i also had changed broadband supplier) for the line to sort itself out it was up and running and synchronized within 30 minutes or less, but bear in mind it does purely work with the broadband line (i also got another number with it) so dont rely on it for emergency calls. the tariff for calling is cheaper over broadband when contacting family oversea's, and the line is crisp and clear, it is easy to navigate through the phones memory and is easy to set the prefference for what rings if you use the Hub manager. overall very good,
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
