Click to visit BT.com
BT.com Checkout Wishlist
Your basket is empty
BT Home Hub 5
with superfast ac wireless technology & 4 GigE ports
BT Home Hub 5
Customer rating:4.0*
Quicklinx: 90RYWS00
Mfr#: 068343
Express delivery Order within the next 3 hours for delivery tomorrow
More than 50 in stock
£129.00
Essential accessories
New BT Home Hub 5
The all new BT Home Hub 5 builds upon the unrivalled reliability of BT Home Hub 4 and adds:
Superfast 802.11ac wireless: The new smart ac wireless on the Hub 5 supports full Infinity 2 speeds wirelessly. This the best out of BT Infinity fibre optic broadband whatever you use it for. This makes Hub 5 one of the fastest in the UK!
Four GigE ports so customers can further exploit the superfast speeds of their Infinity Broadband.
BT dual-band ac wireless USB dongle (Sold separately. Available to buy for £34.99)
The BT dual-band ac wireless USB dongle for Windows PCs greatly improves the Wi-Fi performance of your laptop when used with the BT Home Hub 5. The easy to install dual-band dongle is compatible with Windows Vista, Windows 7 and Windows 8 only.
An integrated VDSL modem meaning that most Infinity customers will no longer need two separate boxes
Additionally, the BT Home Hub 5 will keep the brilliant features introduced in BT Home Hub 4, including Smart Dual-Band technology, Smart Setup and a great new design that fits through most letterboxes* as well as a processor that is 3 times faster than other most common wireless routers.
Smart dual-band technology reduces wireless interference and drop outs, giving our customers an unbeatable connection for all their devices.
Smart Setup: Easy set up in just a few minutes. You don't need a CD or disc drive, it's all online and works on most devices. Set up your new Home Hub and get to all your inclusive extras, like BT Cloud, Desktop Help and BT Family Protection, in just a few clicks
*If you select a tracked or next day delivery service, courier may not be able to post the BT Home Hub 4 through your letterbox
Ports and Sockets * DSL network interface for BT Broadband and Infinity * 1x RJ45 Gigabit WAN interface * 4x RJ45 Gigabit Ethernet LAN ports * 1x USB 2.0 master socket
Wireless * Dual band concurrent wireless * 2.4GHz: 802.11n dual-stream 2x2 MIMO. Back compatible with 802.11 b/g * 5GHz: 802.11ac dual-stream 3x3 MIMO. Back compatible with 802.11n/b/g - AC new wireless standard * WPS wireless connection * Smart Wireless - automated channel selection in 2.4 & 5GHz * Wireless channel operation * 2.4GHz: 20MHz (default), 40MHz supported * 5GHz: 80MHz (default), 40MHz supported * Up to 64 simultaneous wireless users supported Wireless encryption * 2.4GHz: WPA2 (default), WPA, WPA2 and WEP 64/40 * 5GHz: WPA2
Wireless Transmission speed * 2.4GHz wireless: up to 300Mbps * 5 GHz wireless: up to 1300Mbps * Up to 300 Mbps (40MHz) * Up to 1300 Mbps (80MHz)
Buttons * Wireless: WPS * Reset (Pinhole) * Restart * On/Off power button
LED * Power * Broadband * Wireless
Weight & dimensions * 290 (g) (+ PSU 176g) * 116 high x 236 wide x 31 deep (mm)
Power consumption * Latest intelligent power management; hub functions are monitored and individually put into power save mode when not in use.
Other features * Packaging designed to fit through typical UK letter box * Smart Set Up - new CD-less installation * Support for BT Wifi
Resources
The following resources are available for the BT Home Hub 5
Customer reviews
Write a review for the BT Home Hub 5 here!
BT Home Hub 5
4.0 31
£129.00
BT Home Hub 5
download speed
Reviewed by . Review Posted 10/04/2015
5 5
not as fast as i expected the first time iused it was super fast seems to have slowed over time
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Better than the Home Hub 4
Reviewed by . Review Posted 02/07/2014
5 5
I bought the Home Hub 5 to replace my Home Hub 4. The HH4 had an irritating fault that others seemed to have found when I searched the Internet, but BT Customer Services refused to acknowledge. Periodically, the HH4 would be rebooted remotely by a BT server. When this happened, the 2.4 GHz wireless stopped working. The only way to get it back was to reset to the factory defaults and then waste 15 minutes reconfiguring all my personal settings back into the router. After several months with the HH5, so far there have been no problems. The HH5 also eliminates the need for a separate modem, which is a bonus.
  • Overall 5*
  • Ease of use 5*
Apple Time Machine
Reviewed by . Review Posted 29/06/2014
5 5
Upgraded because of the faster wireless speeds that had meant doing an Apple Time machine took days and wasn't disappointed. A full back up was achieved in under 48 hours on a n iMac which previously took 6 days. Top product. Well done BT
  • Overall 5*
  • Ease of use 5*
infinty at its best
Reviewed by . Review Posted 09/05/2014
5 5
Ordered home hub 5 as really wanted a neater single box solution, what I ended up with was much more,be score to bt finally putting an end to needed a horrid white box! I don't have any equivalent to take advantage of the newest wireless standard so I wasn't expecting a change in wireless performance,but it's a huge difference my 60mbps+ internet connection is really being utilised and everything is loading instantaneously, well done BT great piece of kit, best hub yet,neater,faster, better looking, just plain awesome
  • Overall 5*
  • Ease of use 5*
The Best Yet.
5 5
This is BT's best hub yet. It is simple to set up it does exactly what BT says it will do. I have used all the BT Hubs from One through Five and this one is brilliant.
  • Overall 5*
  • Ease of use 5*
bthomehub5
Reviewed by Anonymous Review Posted 20/03/2014
5 5
ok khrap
  • Overall 5*
  • Ease of use 5*
  • Value for money 4*
In hock to Windows
5 5
Why cannot BT produce a dongle for Apple Mac and Linux - not all their customers use or want to use Windows,
  • Overall 5*
  • Ease of use 5*
Can't understand all the negative comments!
Reviewed by . Review Posted 19/03/2014
5 5
Recently upgraded to BT Infinity and was somewhat miffed with having to have the two boxes. Took a chance and ordered the Hub 5 since it implied I could do away with the Openreach supplied router. Since I was already using the Hub 4 I checked the power supplies of both units matched and simply substituted the Hub 5 for the 4.
Apart from having changing the security PIN on the various devices I use around the house everything is working as before if not better and no loss of signal strength throughout my house. Any use for the Hub 4 and the Openreach router which there was a way of re-cycling these apart from throwing them away as electrical waste. I give it top mark all round my only gripe being I wish it had been out when I upgraded!
  • Overall 5*
  • Ease of use 5*
First BT Home Hub 5
Reviewed by . Review Posted 19/01/2014
5 5
After spending 100's pounds on other routers, this has been my first 10/10. If your pondering to upgrade to the new BT Hub 5. Purchase one straight away. You will not be disappointed with the easy BT setup and fantastic wireless range. The BT Hub 5 has never dropped a connection, unlike other brands of router. Using on BT Infinity now and are getting 70mbs Down/35mbs up thru wireless. Love it.
  • Overall 5*
  • Ease of use 5*
Improved performance and tidier
Reviewed by Anonymous Review Posted 02/12/2013
5 5
I replaced my Hub 4 and white VDSL modem (and mass of connecting cables/wires/power adapters), with this super Hub 5 single unit. The wireless range is better, it has never dropped out since installed and the installation was a 1 minute job, needing no technical expertise!
  • Overall 5*
  • Ease of use 5*
read all 31 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Type: Router
Connection Type: ADSL or VDSL
Standards: IEEE 802.11ac
Speed: 1300Mbps
Rackmount or External: External
Brand: BT
Price Range Inc VAT: 100 - 150
