Click to visit BT.com
BT.com Checkout Wishlist
Your basket is empty
BT Home Hub 4 (BT Broadband Customers)
Customer rating:4.0*
Quicklinx: 8P1MWS00
Mfr#: 068340
Express delivery Delivered on Tuesday
Hurry, only 1 left in stock!
£109.00
New BT Home Hub 4
Our best ever router!
The BT Home Hub 4 is BT's best hub yet. Only BT's new Hub 4 has Smart Dual band technology which reduces wireless interference and drop-outs for the UK's most reliable connection. It has a faster processor that mean it will make any home network faster. With Smart Setup it's easy to set up on any device and you don't need a PC to setup your BT broadband. Plus it has a new slim line design that looks great!
Only BT's Home Hub 4 has smart dual-band technology, for the UK's most reliable wireless connection for all your devices.
Smart dual-band technology which reduces wireless interference and drop out.
Easy set up in just a few minutes. No CD or computer needed, it's all online and works on any device.
Easy wireless connection for any compatible device at the push a button on the Hub without any passwords needed.
Faster processor which allows you to transfer files from one connected device to another faster than ever.
Smart diagnostics which automatically check the Hub is working properly and alert you to any issues and present advice on how to solve them.
Premium design which is sleek and slim.
Ports and Sockets
  • ADSL network interface for BT Broadband
  • 1x RJ45 Gigabit WAN interface for BT Infinity
  • 4x RJ45 Ethernet LAN ports
  • 1x Gigabit Ethernet
  • 3x 10/100 Base T Ethernet
  • 1x USB 2.0 master socket x1
Buttons
  • Wireless: WPS
  • Reset (Pinhole)
  • Restart
  • On/Off power button
LED
  • Power
  • Wireless
Weight & dimensions
  • 301 (gms)
  • 116 high x 236 wide x 31 deep (mm)
Wireless
  • Dual band concurrent wireless
  • 2.4GHz: 802.11n dual-stream 2x2 MIMO. Back compatible with 802.11 b/g
  • 5GHz: 802.11n dual-stream 2x2 MIMO. Back compatible with 802.11a
  • WPS wireless connection
  • Smart Wireless - automated channel selection in 2.4 & 5GHz
  • Wireless channel operation
  • 2.4GHz: 20MHz (default), 40MHz supported
  • 5GHz: 40MHz (default), 20MHz supported
  • Up to 64 simultaneous wireless users supported
Wireless encryption
  • 2.4GHz: WPA & WPA2 (default), WPA, WPA2 and WEP 64/40
  • 5GHz: WPA2
Wireless Transmission speed
  • 2.4GHz wireless: up to 300Mbps
  • 5 GHz wireless: up to 300Mbps
  • Up to 150 Mbps (20MHz)
  • Up to 300 Mbps (40MHz)
Power consumption
  • Latest intelligent power management; hub functions are monitored and individually put into power save mode when not in use.
Other features
  • Packaging designed to fit through typical UK letter box
  • Smart Set Up - new CD-less installation
  • Support for BT Wifi
Customer reviews
Write a review for the BT Home Hub 4 (BT Broadband Customers) here!
4.0 27
£109.00
A second hub 4 review
Reviewed by . Review Posted 19/06/2013
5 5
A company that responds to customer reviews. Many of us felt the new Hub 4 was much too expensive especially to existing customers. Well done BT - you're now offering it at a much more reasonable price and I've therefore just ordered one.
  • Overall 5*
  • Ease of use 5*
  • Value for money 4*
Much improved on Home Hub 2 and 3
Reviewed by . Review Posted 07/06/2013
5 5
I have now had my Home Hub 4 for 24 hours. We live in the country, miles from our exchange, so the broadband speed is painfully slow on a good day and we need something that makes the most of what speed we do have. Our house is old, with very thick, stone walls and is a long, single storey L-shape, with the master socket at one end of the L - distinctly wi-fi unfriendly - but this hub manages to get the signal all over the house with full bars. So far, there have been no dropped connections and it handles multiple devices much better than our previous hubs. It was a doddle to set up and is visually, a much better design, taking up less space too. It comes with a nice long power cable too. Can't fault it at the moment and it was £41.95 well spent! (Also the box it is sent out in gives you prepaid postage to return a Home Hub 3 for full recycling. If you have a Home Hub 2, you can send that back in the box to be disposed of by BT, but you have to pay the postage for that.)
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
peter
Reviewed by Anonymous Review Posted 21/11/2013
5 5
ok
  • Overall 5*
  • Ease of use 5*
Home Hub 4
Reviewed by . Review Posted 28/06/2013
5 5
Reading the reviews I ordered a Home Hub4 as an existing customer for £35 + delivery. I can only assume that the people complaining about the high price to existing customers have not followed the upgrade link in my broadband.
  • Overall 5*
  • Ease of use 5*
Thank You
5 5
Thank you very much Karen for your instructions re: ordering the Home Hub 4 for £35. I couldn't seem to find it anywhere and I needed to replace my Home Hub 2 as it was suffering from repeated drop outs and having to be reset. once again Thank you.
  • Overall 5*
  • Ease of use 5*
B.T HUB 4
Reviewed by . Review Posted 05/06/2013
5 5
I did the same as Karen and ordered the hub and the dongle which is also good value at £9.
  • Overall 5*
  • Ease of use 5*
Cheaper for BT customers
Reviewed by . Review Posted 04/06/2013
5 5
Just bought one for £35 + p&p (£41.95 in total)
Just log in to your myBT account and go to My Broadband. There there is an option to upgrade to a BT Home Hub 4. Select Home Hub 4 from menu on left. Select middle tab "BT Home Hub". click buy now, select your phone number and wait for them to confirm that you are a customer. Then order either completely through a credit or debit card or pay p&p that way and add cost of hub to your next bill.
  • Overall 5*
  • Ease of use 5*
BT router 4
Reviewed by . Review Posted 03/06/2013
5 5
Spoke to BT this PM (3 JUNE 2013) item is £109 for BT Broadband customers!!!
  • Overall 5*
  • Ease of use 5*
REPRIEVE FORBT BAD PUBLICITY RE PRICE OF HOME HUB 4
Reviewed by . Review Posted 21/05/2013
5 5
I recently posted a poor rating for BT's Home Hub 4 on the grounds that it is being offered for £109 at present to BT Customers. I have been in contact with BT by Telephone, and it appears that from 1st June 2013 it is being offered for £35 + Postage to BT Broadband Customers which for a dual band router is most definitely a BARGAIN. I will be placing my order on 1st June, and will be remaining with BT for the foreseeable future!!
  • Overall 5*
  • Ease of use 5*
BT Home Hub 4
5 5
Dear BT, Sometimes you make the most appalling errors of judgement. I would really like to update to the new Hub 4 but the cost is totally ridiculous, especially for existing customers.
  • Overall 5*
  • Ease of use 5*
  • Value for money 1*
read all 27 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
