Click to visit BT.com
BT Graphite 1500 Trio Cordless Phone With Answer Machine
BT BT Graphite 1500 Trio Cordless Phone With Answer Machine
Quicklinx: 4XZ4WS00
Mfr#: 038560
FREE DELIVERY ON ALL BT PHONES!
Customer rating
2.0*
View reviews
Key Features
Digital answering machine with up to 12 minutes recording time
Choice of 2 pre-recorded outgoing messages (answer & record and answer only) or you can record your own. There is a memo feature so you can leave messages for other people in the home or office and you can also access your answering machine remotely and listen to your messages when you are away from home.
10 Last number redial
Easily redial any of the last 10 numbers called using the redial list.
50 Entry phonebook
Store up to 50 of your most frequently used numbers to make dialling quick and easy.
Caller Display with 40 number calls list(1)
See who is calling you before you answer the phone. The calls list holds details of your last 40 callers, including the phone number and time and date of the call.
Handsfree handset speaker
Need both hands free? Press the Handsfree button and continue the call without needing to hold the handset. Because you can hear and speak to your caller through the handsfree speaker, other people can join in the conversation.
Call Waiting(1)
Call Waiting alerts you with a soft beep if someone tries to call while you are already on the phone. Used with Caller Display, you can see who the second caller is.
Add extra handsets without adding phone sockets
Use up to 5 GAP compatible handsets with the BT Graphite on a single phone line - using just one phone socket.
Have you got enough handsets?
The BT Graphite 1500 range is available in 1, 2, 3 or 4-Pack versions. You can have a phone in each room - without the need for extra wiring or phone sockets.
Additional features
  • Call Waiting(1)
  • 10 Last number redial
  • Secrecy facility
  • Alarm setting
  • 5 handset/5 base ringer melodies
  • Base and handset ringer volume control
  • Earpiece volume control
  • Keypad lock
  • Handset power on/off
  • Auto talk feature
  • Up to 10 hours talktime and
  • 100 hours standby time(2)
  • Range of up to 300 metres outdoors and 50 metres indoors(3)
  • Out of range/battery low warnings
Answering machine features
  • Up to 12 minutes recording time
  • Pre-recorded outgoing messages: answer & record and answer only
  • Call screening/call intercept
  • Memo facility
  • Answer delay setting
  • Base unit loudspeaker
  • Remote access
Multi-handset features
  • GAP compatible - register up to 5 handsets to one base
  • Internal calls
  • Call transfer
  • 3-Way calling
This pack contains
  • 1 x BT Graphite 1500 base
  • 2 x BT Graphite 1500 charger
  • 3 x BT Graphite 1500 handsets
  • 3 x Battery compartment covers
  • 6 x NiMH AAA rechargeable batteries
  • 3 x Mains power adaptors
  • Telephone line cord
  • Quick Start Guide
WARNING
Radio signals from this product can interfere with hearing aids, causing a humming noise. It is also recommended to check with your medical advisor if you have a pacemaker fitted.
WARNING
This equipment is not designed for making emergency telephone calls when the power fails. Alternative arrangements should be made for access to emergency services.
We do our best to supply our customers with the apparatus they ask for, but we may have to provide apparatus which does not accord exactly with the illustrations and shades of colour shown on the pack.
This product is intended for connection to analogue public switched telephone networks and private switchboards in the UK.
(1) You must subscribe to a Caller Display or Call Waiting service for these features to work. Your network provider may charge you for these services. (2) When batteries are fully charged.
(3) In ideal conditions.
† Trademark of British Telecommunications plc.
Where described as VoIP compatible, this applies when used with the appropriate VoIP service such as BT's Broadband Talk service and hardware such as the BT Home Hub - it is not a standalone voip phone
Image gallery
Select any thumbnail below to view a larger image.
Resources
The following resources are available for the BT Graphite 1500 Trio Cordless Phone With Answer Machine
Customer reviews read all 2 customer reviews
Write a review for the BT Graphite 1500 Trio Cordless Phone With Answer Machine here!
Good Enough
Reviewed by David Owen. Review Posted 16/11/2009
It does what it says on the box, ok it doesn't have a large backlit screen but it functions well as a phone, is clear and relativly easy to get the most out of, the answering machine is adequate if not startling and the build quality and ergonomices are ok as well.
For the money its ok.
  • Overall 3*
  • Ease of use 4*
  • Value for money 5*
Graphite 1500
Reviewed by Anonymous Review Posted 01/06/2010
I returned this phone as when you have the loudspeaker on the volume cuts in and out which is really annoying as I like to have the phone on loudspeaker when I am on hold for a long time or when I want other people to be able to hear. However every other secong the sounds would cut out. I assumed this was a fault with my phone and asked for a replacement phone but the new replacement had exactly the same problem. I also found it was too easy to cut someone off by mistake as the button which disconnects calls is easily pressed if you are holding the phone up to your face. A very cheap and unimpressive phone. I am looking for a better quality model with transferable phone book and a good louspeaker which actually works
  • Overall 1*
  • Ease of use 2*
  • Value for money 3*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Accessories
1-1 products displayed out of 1
  product description   In stock inc VAT qty
  Durable 5758 Telephone Cleaning Wipes - Box of 100 Durable 5758 Telephone Cleaning Wipes - Box of 100
quicklinx: 4GWTWS00 | Mfr#: 5758
Available £3.12
