Click to visit BT.com
BT Graphite 1500 Single Cordless Phone
BT Graphite 1500 Single Cordless Phone Image for illustration only
BT BT Graphite 1500 Single Cordless Phone
In stock now
Quicklinx: 4XZ2WS
Mfr#: 038558
£39.98 inc vat
Key Features
Digital answering machine with up to 12 minutes recording time
Choice of 2 pre-recorded outgoing messages (answer & record and answer only) or you can record your own. There is a memo feature so you can leave messages for other people in the home or office and you can also access your answering machine remotely and listen to your messages when you are away from home.
10 Last number redial
Easily redial any of the last 10 numbers called using the redial list.
50 Entry phonebook
Store up to 50 of your most frequently used numbers to make dialling quick and easy.
Caller Display with 40 number calls list(1)
See who is calling you before you answer the phone. The calls list holds details of your last 40 callers, including the phone number and time and date of the call.
Handsfree handset speaker
Need both hands free? Press the Handsfree button and continue the call without needing to hold the handset. Because you can hear and speak to your caller through the handsfree speaker, other people can join in the conversation.
Call Waiting(1)
Call Waiting alerts you with a soft beep if someone tries to call while you are already on the phone. Used with Caller Display, you can see who the second caller is.
Add extra handsets without adding phone sockets
Use up to 5 GAP compatible handsets with the BT Graphite on a single phone line - using just one phone socket.
Have you got enough handsets?
The BT Graphite 1500 range is available in 1, 2, 3 or 4-Pack versions. You can have a phone in each room - without the need for extra wiring or phone sockets.
Additional features
  • Call Waiting1
  • 10 Last number redial
  • Secrecy facility
  • Alarm setting
  • 5 handset/5 base ringer melodies
  • Base and handset ringer volume control
  • Earpiece volume control
  • Keypad lock
  • Handset power on/off
  • Auto talk feature
  • Up to 10 hours talktime and
  • 100 hours standby time(2)
  • Range of up to 300 metres outdoors and 50 metres indoors(3)
  • Out of range/battery low warnings
Answering machine features
  • Up to 12 minutes recording time
  • Pre-recorded outgoing messages: answer & record and answer only
  • Call screening/call intercept
  • Memo facility
  • Answer delay setting
  • Base unit loudspeaker
  • Remote access
This pack contains
  • BT Graphite 1500 base
  • BT Graphite 1500 charger
  • 1x BT Graphite 1500 handset
  • 1x Battery compartment cover
  • 2x NiMH AAA rechargeable batteries
  • 1x Mains power adaptor
  • Telephone line cord
  • Quick Start Guide
WARNING
Radio signals from this product can interfere with hearing aids, causing a humming noise. It is also recommended to check with your medical advisor if you have a pacemaker fitted.
WARNING
This equipment is not designed for making emergency telephone calls when the power fails. Alternative arrangements should be made for access to emergency services.
We do our best to supply our customers with the apparatus they ask for, but we may have to provide apparatus which does not accord exactly with the illustrations and shades of colour shown on the pack.
This product is intended for connection to analogue public switched telephone networks and private switchboards in the UK.
(1) You must subscribe to a Caller Display or Call Waiting service for these features to work. Your network provider may charge you for these services. (2) When batteries are fully charged.
(3) In ideal conditions.
† Trademark of British Telecommunications plc.
Where described as VoIP compatible, this applies when used with the appropriate VoIP service such as BT's Broadband Talk service and hardware such as the BT Home Hub - it is not a standalone voip phone
Image gallery
Select any thumbnail below to view a larger image.
Resources
The following resources are available for the BT Graphite 1500 Single Cordless Phone
Accessories
1 - 1 products displayed out of 1
  product description   In stock inc vat qty
  Durable 5758 Telephone Cleaning Wipes - Box of 100 Durable 5758 Telephone Cleaning Wipes - Box of 100
quicklinx: 4GWTWS | Mfr#: 5758
Due in 1-2 days £2.57
feature value
Type Cordless phone
Answer Machine Yes
Handsets Included 1
Brand BT
Stock Status In Stock
Price Range Inc VAT 0 - 50
My BT Shop Basket
your basket is empty
Add an item by clicking
Mini basket dummy button. This button serves as indication only
next to the product of your choice.
Free Delivery on BT branded products - click for details
