BT Graphite 1100 Twin Cordless Phone
Customer rating
View reviews
Key Features
Store up to 50 of your most frequently used numbers to make dialling quick and easy.
Need both hands free? Press the Handsfree button and continue the call without needing to hold the handset. Because you can hear and speak to your caller through the handsfree speaker, other people can join in the conversation.
See who is calling you before you answer the phone. The calls list holds details of your last 40 callers, including the phone number and time and date of the call.
Call Waiting alerts you with a soft beep if someone tries to call while you are already on the phone. Used with Caller Display, you can see who the second caller is.
Use up to 5 GAP compatible handsets with the BT Graphite on a single phone line - using just one phone socket.
The BT Graphite 1100 range is available in 1, 2, 3 or 4-Pack versions. You can have a phone in each room - without the need for extra wiring or phone sockets.
We do our best to supply our customers with the apparatus they ask for, but we may have to provide apparatus which does not accord exactly with the illustrations and shades of colour shown on the pack.
This product is intended for connection to analogue public switched telephone networks and private switchboards in the UK.
1 You must subscribe to a Caller Display or Call Waiting service for these features to work. Your network provider may charge you for these services. 2 When batteries are fully charged.
3 In ideal conditions.
† Trademark of British Telecommunications plc.
WARNING
Radio signals from this product can interfere with hearing aids, causing a humming noise. It is also recommended to check with your medical advisor if you have a pacemaker fitted.
WARNING
This equipment is not designed for making emergency telephone calls when the power fails. Alternative arrangements should be made for access to emergency services.
Select any thumbnail below to view a larger image.
The following resources are available for the BT Graphite 1100 Twin Cordless Phone
Write a review for the BT Graphite 1100 Twin Cordless Phone here!
There does not appear to be a way to copy phonebooks between phones. This makes it very unhelpful to keep each phonebook upto date. Otherwise phone good value for medium-priced wireless phone.
The phone is difficult to read and display needs backlit.
The range is not good.
On speakerphone the voice comes and goes making it difficult to understand what is being said.
I would not buy this phone again.
I had a Freestyle 1025 which was a better phone but after 5 years now buzzes during conversations
Poor quality, stopped functioning after 14 months. Bought again (my mistake) and after just over a year there's so much inteference on the line I'll have to buy a new phone (not this one).
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
