BT Graphite 1100 Trio Cordless Phone
Key Features
Store up to 50 of your most frequently used numbers to make dialling quick and easy.
Need both hands free? Press the Handsfree button and continue the call without needing to hold the handset. Because you can hear and speak to your caller through the handsfree speaker, other people can join in the conversation.
See who is calling you before you answer the phone. The calls list holds details of your last 40 callers, including the phone number and time and date of the call.
Call Waiting alerts you with a soft beep if someone tries to call while you are already on the phone. Used with Caller Display, you can see who the second caller is.
Use up to 5 GAP compatible handsets with the BT Graphite on a single phone line - using just one phone socket.
The BT Graphite 1100 range is available in 1, 2, 3 or 4-Pack versions. You can have a phone in each room - without the need for extra wiring or phone sockets.
We do our best to supply our customers with the apparatus they ask for, but we may have to provide apparatus which does not accord exactly with the illustrations and shades of colour shown on the pack.
This product is intended for connection to analogue public switched telephone networks and private switchboards in the UK.
1 You must subscribe to a Caller Display or Call Waiting service for these features to work. Your network provider may charge you for these services. 2 When batteries are fully charged.
3 In ideal conditions.
† Trademark of British Telecommunications plc.
WARNING
Radio signals from this product can interfere with hearing aids, causing a humming noise. It is also recommended to check with your medical advisor if you have a pacemaker fitted.
WARNING
This equipment is not designed for making emergency telephone calls when the power fails. Alternative arrangements should be made for access to emergency services.
Select any thumbnail below to view a larger image.
The following resources are available for the BT Graphite 1100 Trio Cordless Phone
