Click to visit BT.com
BT.com Checkout Wishlist
Your basket is empty
BT Dual-band AC Wireless USB Dongle
Customer rating:3.0*
Quicklinx: 90RZWS00
Mfr#: 068807
Standard delivery Delivered within 3 working days once we receive stock
The BT dual-band ac wireless USB dongle allows you to take advantage of the brand new AC wireless technology that comes with the BT Home Hub 5.
The new smart ac wireless on the Hub 5 supports full Infinity 2 speeds wirelessly. This offers the best out of BT Infinity fibre optic broadband whatever you use it for. This makes Hub 5 one of the fastest in the UK!
Some of the latest devices like the Samsung Galaxy S4 or the latest Apple MacBook Air come with AC built in. However, this brand new dongle provides Dual-Band ac wireless for devices that don't support this technology and allows you to enjoy the benefits of ac wireless on your existing devices.
It is compatible with Windows Vista, 7 and 8.
Why not add up to 3 dongles to your order and get the most from BT Infinity from most or all of your laptops!
This device is a 802.11 a/b/g/n/ac Dual Band Wireless LAN USB Dongle for use with desktop PCs, laptops and other compatible devices to allow wireless connection to 2.4GHz and 5GHz Access Points and adhoc connection to other clients.
*Highly integrated single chip CMOS solution, minimizing power consumption and cost while maximizing reliability *Fully supports 5GHz Dynamic Frequency Selection (DFS) and Transmit Power Control (TPC) from 802.11h, WMM (QoS) from 802.11e.
Technical Specifications *Standard - 2.4GHz 802.11b/g/n *5GHz 802.11a/n/ac Modes 2.4GHz: *20MHz: 802.11b/g *40MHz: 802.11n 5GHz: *20MHz: 802.11a/n/ac *40MHz: 802.11n/ac *80MHz: 802.11ac *Interoperability: The device shall interoperate with all major 802.11ac AP chipsets. **Antenna type: 2x2 MIMO internal antenna
Software *OS Support Windows Vista, 7, 8. This shall include both 32bit and 64bit versions and all service packs unless otherwise stated. *Mac OSX is not supported *Certified for Windows (WHQL) *Windows Vista, 7, 8 Both 32 & 64bit versions for each OS. **Installation Experience Windows certified drivers shall be distributed via Windows update.
Customer reviews
Write a review for the BT Dual-band AC Wireless USB Dongle here!
3.0 3
£34.99
USB Dongle
Reviewed by Anonymous Review Posted 14/11/2013
5 5
Ok looking foreword to receiving the dongle
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
BT 900 Dongle
Reviewed by . Review Posted 20/03/2014
1 5
Possibly the worst dongle I have ever purchased. No instructions with product and when I found them on a BT page the instructions bore no resemblance to reality. Spent hors trying to get it to work properly. Good job it's become unavailable.
  • Overall 1*
  • Ease of use 1*
  • Value for money 1*
Useless for my needs.
Reviewed by . Review Posted 09/03/2014
1 5
This dongle is too wide for fitting to the USB port. My laptop has just 2 ports for USB. One of these is taken by the mouse dongle so the BT dongle wont fit. Also everytime i put the BT Dongle into the USB after removing the mouse the laptop crashed and would not start..... Come on BT most people will use this dongle for laptops , please make it smaller so it does not take up so much room
  • Overall 1*
  • Ease of use 1*
  • Value for money 3*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
