Click to visit BT.com
BT.com Checkout Wishlist
Your basket is empty
BT Business Hub 3
BT Business Hub 3
Quicklinx: 80QCWS00
Mfr#: 64422
Express delivery Delivered on Tuesday
£63.54
Our latest hub is designed to make the most of superfast broadband speeds and has innovative features making it more efficient, reliable, secure and easier to use, as well as environmentally friendly.
It also gives you the UK's most reliable wireless connection. Our Smart Wireless™ technology means you get the strongest signal possible from the BT Business Hub 3 to your devices compared with other major broadband providers.
Wireless-N Technology - A smart antenna and signal processing that gives up to five-times the performance and up to twice the range, compared to our previous BT Business Hub.
Smart Wireless™ - Chooses your clearest signal at any time to give you the UK's most reliable connection from hub to device compared to all other major broadband providers.
Wi-Fi Protected Setup (WPS) - New wireless networks are automatically configured, so new devices can be added without the need for wi-fi expertise.
Gigabit Ethernet - The capability to keep up with superfast broadband. Multiple users will experience faster performance.
Energy Efficiency - Uses 30% less energy (half the power of an energy-efficient lightbulb), and goes into power save mode as soon as there is no traffic.
Fibre Support
Modem Type
ADSL2+
Access Methods supported
IP Stream, ADSL, FTTC & FTTP
802.11b support
802.11g support
802.11n support
Draft 802.11n 5GHz support
No
Stated Speed
3 x 10/100 Mbit/s Ethernet sockets (RJ45), 1 x 10/100/1000 Mbit/s Ethernet socket (RJ45)
128-bit WEP
WPA
PSK
Firewall
MAC Address Filtering
DMZ
WPS
Size
107x185x62mm
Antennas
2
Internal/External antennas
Internal
Number of WAN ports
2 (1 x DSL and x Ethernet)
Ethernet ports
4
Ethernet connection speed
10/100/1000Mbit/s
Other ports
USB
Type: Wireless router
Connection Type: ADSL (BT)
Brand: BT
Price Range Inc VAT: 50 - 100
