Click to visit BT.com
BT.com
Wishlist
BT BT Decor 1300 Corded Phone
3.0*
Quicklinx: 4CYMWS00
Mfr#: 024864
The BT Decor 1300 has a two line LCD screen with contrast control, Caller Display, a clock with date, day and month. It has features such as polyphonic ring tones, 100 names and numbers directory, control, time and date stamp, store, secrecy, pause and recall buttons. Wall mountable, it is PBX compatible and supports TouchTone dialing.
Key Features:
  • LCD screen
  • Ring indicator light
  • Polyphonic ring tones - 0
  • Pause
  • Recall
  • Last number redial
  • Ringer hi-low-off
  • Secrecy
  • Mute button
  • Store button
  • Touch tone dialling compatible
  • Wall mountable
  • 1571 network message detection
  • Speech amplification volume control
  • Speaker Volume Control
  • Pre-dialling facility
*In order to see who is calling you will need to subscribe to the BT Caller Display Service which is available when you sign up to www.bt.com/btprivacy BT residential customers making some calls on the BT network can opt in to receive Caller Display at no extra charge, subject to availability. Analogue lines only. Numbers will not be registered if the call is from payphones, some switchboards, and non-BT networks or where a caller's number is withheld.
Where described as VoIP compatible, this applies when used with the appropriate VoIP service such as BT's Broadband Talk service and hardware such as the BT Home Hub - it is not a standalone voip phone
BT Decor 1300 - corded phone with caller ID
Corded phone with caller ID
Speakerphone
Caller ID
Call Services
Caller ID
Speed Dial Capacity
10
Display
LCD display - monochrome
Body Colour
Arctic grey
1 year warranty
Corded phone
Body Colour
Arctic grey
Phone Features
Call Services
Caller ID
Caller ID Type
Caller ID
Dialer Type
Keypad
Dialer Location
Base
Speakerphone
Menu Operation
Function Buttons
Recall button, 1571, memory pause button, mute button
Volume Control
Ringer Control
Additional Functions
Call timer, built-in clock, Time/Day Stamp
Phone Memory
Phone Directory Capacity
100 names & numbers
Dialed Calls Memory
1
Speed Dial Capacity
10
Display
Display Location
Base
Line Qty
2
Placing / Mounting
Wall-mountable
1 year warranty
Service & Support Details
Limited warranty - 1 year
4CYM BT ADSL Micro Filter RS In Stock £5.22
Resources
The following resources are available for the BT BT Decor 1300 Corded Phone
Customer reviews
Write a review for the BT BT Decor 1300 Corded Phone here!
BT Decor goes beyond great
Reviewed by steven scott. Review Posted 15/06/2007
I bought the BT Decor 1300 when I got my line installed. When I first looked at the phone I was stunned at the amount of features this phone has. You can change the colour of the screen which is handy for if it's wall mounted so it matches the 'decor' of the wall, it tells you by means of a flashing 1571 button whether you have a message waiting and my favourite is the handsfree/loudspeaker option, as I have kids it's hard to keep a hold of a handset while tending to there needs. I can have a conversation on the phone and still be able to do other things. The volume is adjustable and can be easily heard in another room. However the person on the other end may have dificulty hearing you as you move farther away. I was amazed at all that this phone has to offer and at an incredible price. It's stylish, very practicle and easy to use.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Decor 1300
Reviewed by Peter. Review Posted 15/09/2011
Product description refers to 10 number quick dial facility.This is not true-it does not exist. Otherwise a reasonable'phone. The instruction book is the worst I have ever had-it gives VERY limited information.
  • Overall 3*
  • Ease of use 4*
  • Value for money 3*
Not all it claims
Reviewed by Frank. Review Posted 01/10/2009
This phone claims to have a "speaker volume control". This applies only to the hands-free speaker, not the speaker in the handset. It is useless for the hard-of-hearing, and in fact the handset volume is lower than most other phones. The system of stored numbers being in a list on the screen is not user-friendly. The screen can be in different fancy colours but is difficult to read. Quality of construction is poor and not up to the standard of earlier BT phones. If you are under 21 with perfect eyesight and hearing this phone is for you. If you are over 25 with diminishing eyesight and hearing then look elsewhere!
  • Overall 1*
  • Ease of use 2*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
