Click to visit BT.com
BT.com Checkout Wishlist
Your basket is empty
BT Broadband Extender Flex 500 Kit
Customer rating:5.0*
Quicklinx: 8W3VWS00
Mfr#: 075597
Express delivery Order within the next 12 hours for delivery tomorrow
48 in stock
£69.99
Works with any Broadband provider
BT's Broadband Extender Flex 500 Kit has been designed to work with any service provider to make sure everyone can make the most of their Broadband at home.
What does BT’s Broadband Extender Flex 500 Kit give you?
Connect any wired device to your home broadband anywhere in your home with our powerline technology and enjoy the full broadband experience.
Plug & Play - No install necessary, just instant access to your broadband anywhere in your home!
Everyone loves to be online; and why should you settle for anything other than the complete broadband experience? With BT’s Broadband Extender Flex 500 Kit, you are able to connect any wired device wherever and whenever you like.
With up to 500 Mbps for smooth HD/3D streaming, online gaming or faster downloads, BT's Broadband Extender Flex 500 Kit supports all your online needs.
Simple to use
BT’s Broadband Extender Flex 500 Kit is easy to use. Simply plug into your wall socket and you are ready to enjoy a complete broadband experience. You also won’t lose a socket with the pass through socket included!
Make the most of your Broadband
BT's Broadband Extender Flex 500 Kit offers the solution to a number of your broadband problems. Be it connecting a Smart TV in a different room to your router, using an old laptop without Wi-Fi capability or getting the best online gaming experience possible, BT's Broadband Extender Flex 500 Kit can be used to help make the most of your Broadband at home.
Compatible with other technologies
BT's Broadband Extender Flex 500 Kit works seamlessly with all other BT Broadband Extender products to create your new home network. It is also completely compatible with other AV HomePlug powerlines so you can integrate it with any existing Powerline network. The Broadband Extender Flex 500 Kit utilises HomePlug AV500 Powerline technology and can be fully integrated with an existing AV200 network in your home.
Better for the environment
Eco credentials come as standard with built-in power saving and fully recyclable packaging.
Not the right Broadband Extender for you?
BT has a whole range of Broadband Extenders to meet your requirements. Whether you don't want to lose a socket, need to connect multiple devices or prefer to connect wirelessly, BT has the solution.
Resources
The following resources are available for the BT Broadband Extender Flex 500 Kit
Customer reviews
Write a review for the BT Broadband Extender Flex 500 Kit here!
5.0 4
£69.99
An excellent bit of kit!
Reviewed by . Review Posted 15/08/2014
5 5
My nearest exchange is 2 miles away so my download speeds are not great, around 2.5mbps, making it almost impossible to get BBC iPlayer etc on my tv BUT with the BT Broadband Extender Flex 500 Kit I can now stream BBC iPlayer to my tv without a hitch. My pc is located upstairs away from my tv which is in my lounge downstairs. I do not understand how the extender works but despite being told by "doubting Thomas's" that the extender will only work if my sockets are all on the same electrical ring main (my house is on two, one for upstairs and one fore downstairs) I thought I'd take a chance and try it. AND BINGO they work!! Thank you BT, now that I'm 'plugged in' I can watch BBC iPlayer uninterrupted without endless loss of wireless signal. I highly recommend this smart piece of kit and would say to anyone who has the same problem as myself, give it a try - you've nothing to lose!
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
It's the dogs
Reviewed by . Review Posted 12/03/2014
5 5
Ignore the doubters, this really is a POP to install and it works very well
  • Overall 5*
  • Ease of use 5*
ERROE
Reviewed by Anonymous Review Posted 29/08/2013
5 5
ERROR
  • Overall 5*
  • Ease of use 5*
Perfromance very much depends on wiring in your house
Reviewed by Anonymous Review Posted 16/04/2014
3 5
I have 40Mbs plugged direct into the Home Hub but between 8 and 16 Mbs through the BT Broadband Extender Flex 500 Kit. That might be ok but if intermittently disconnects for a couple of minutes at least once and hour which is not acceptable. In a different house it might be great but I will have to run Ethernet cable after all.
  • Overall 3*
  • Ease of use 5*
  • Value for money 2*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Packaged Quantity: 2
Speed: 500Mbps
Connectivity: Wired
Brand: BT
Price Range Inc VAT: 50 - 100
