Click to visit BT.com
BT.com Checkout Wishlist
Your basket is empty
BT Broadband Extender 500 Kit
Save £15! Usually £49.99
Customer rating:4.0*
Quicklinx: 8W3TWS00
Mfr#: 075596
Express delivery Order within the next 11 hours for delivery tomorrow
More than 50 in stock
£34.99
Works with any Broadband provider
BT’s Broadband Extender 500 Kit has been designed to work with any service provider to make sure everyone can make the most of their Broadband around their home.
What does BT’s Broadband Extender 500 Kit give you?
Connect any wired device to your home broadband anywhere in your home with our powerline technology and enjoy the full broadband experience.
Plug & Play - No install necessary, just instant access to your broadband anywhere in your home!
Everyone loves to be online; and why should you settle for anything other than the complete broadband experience? With BT’s Broadband Extender 500 Kit, you are able to connect any wired device wherever and whenever you like.
With up to 500 Mbps for smooth HD/3D streaming, online gaming or faster downloads, BT's Broadband Extender 500 Kit supports all your online needs.
Simple to use
BT's Broadband Extender 500 Kit is easy to use. Simply plug into your wall socket and you are ready to enjoy a complete broadband experience.
Make the most of your Broadband
BT's Broadband Extender 500 Kit offers a solution to a number of your broadband problems. Be it connecting a Smart TV in a different room to your router, using an old laptop without Wi-Fi capability or getting the best online gaming experience possible, BT's Broadband Extender 500 Kit can be used to help make the most of your Broadband at home.
Compatible with other technologies
BT's Broadband Extender 500 Kit BT works seamlessly with all other BT Broadband Extender products to create your new home network. It is also completely compatible with other AV HomePlug powerlines so you can integrate it with an existing Powerline network. The Broadband Extender 500 Kit utilises HomePlug AV500 Powerline technology and can be fully integrated with an existing AV500 network in your home.
Better for the environment
Eco credentials come as standard with built-in power saving and fully recyclable packaging.
Not the right Broadband Extender for you?
BT has a whole range of Broadband Extenders to meet your requirements. Whether you don't want to lose a socket, need to connect multiple devices or prefer to connect wirelessly, BT has the solution.
Resources
The following resources are available for the BT Broadband Extender 500 Kit
Customer reviews
Write a review for the BT Broadband Extender 500 Kit here!
4.0 7
£34.99
New purchase
Reviewed by . Review Posted 07/01/2015
5 5
Not installed at present
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Excellent
Reviewed by . Review Posted 15/12/2013
5 5
This kit was so easy to set up - I just plugged it in and the units communicated with the BT broadband box and existing set up right away. No techy skills required!
  • Overall 5*
  • Ease of use 5*
bt broadband extender 500 kit
Reviewed by . Review Posted 22/12/2013
5 5
great product
  • Overall 5*
  • Ease of use 5*
Excellent
5 5
This kit was so easy to set up - I just plugged them in they communicated with the BT broadband box and existing set up right away. No tetchy skills required!
  • Overall 5*
  • Ease of use 5*
Works fine BUT before buying make sure you have suitable SPARE electric sockets
Reviewed by Anonymous Review Posted 28/03/2014
4 5
This worked fine BUT before buying note it needs two spare wall sockets - not extension lead - for its exclusive use one close to your router and one near to your computer. (The ethernet cables supplied are 2m long so if the distances are greater you will need to buy one or two longer ones.) This is not said explicitly in the info on the website, but is in the info that comes with the product. You do not loose a socket with the more expensive Flex 500, but confusingly one of the pictures on the website info for the 500 shows two Flex 500 extenders.
Also note when looking at reviews BT may not publish all reviews and may edit those they do.
  • Overall 4*
  • Ease of use 5*
  • Value for money 4*
Misunderstood
Reviewed by Anonymous Review Posted 21/04/2015
3 5
I wanted to review further details of the equipment before i bought it.
  • Overall 3*
  • Ease of use 3*
aweful servic
Reviewed by . Review Posted 30/05/2014
1 5
I paid £10 extra for next day delivery 2 days ago and its still not here, pathetic BT
  • Overall 1*
  • Ease of use 1*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Accessories Packaging Functional Software Manuals
Ref: 8W3T 027156
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £685.76
Ref: 8W3T 027160
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Packaged Quantity: 2
Speed: 500Mbps
Connectivity: Wired
Brand: BT
Stock Status: Used Stock
Price Range Inc VAT: 0 - 50
