Click to visit BT.com
BT.com
Wishlist
BT Baby Monitor 200
BT Baby Monitor 200
Customer rating:4.0*
Quicklinx: 79MWWS00
Mfr#: 058296
UK'S No.1 Selling Digital Baby Monitor Brand
BT Baby Monitor 200
A great baby monitor can make a real difference. It'll help make life easier for you, and give you complete reassurance by keeping you close to your baby, even when you're away.
One of the best buys you can make for you and your baby is a baby monitor. The best monitors have grown up and adopted all sorts of new technology, so you'll be amazed by what they can do.
  • Digital DECT technology
  • Hi-definition sound
  • Mute low/mute all
  • Talkback
  • Nightlight
  • Travel bag
  • Volume control
As featured in
White/Purple
Sound level indicator
Power on/off
Nightlight
Sensitivity Control
Battery Type (parent)
NiMH
Belt Clip
No
Volume Control
Battery Size (parent)
AA
Wall Mount
No
Mute
Battery Capacity (parent)
1300mAh
Clock
No
Vibrating Alert
No
Timer
No
Temperature Alert
No
Battery Type (baby)
Alkaline
Out of range alert
Paging
Battery Size (baby)
n/a
Talk Back
Baby Unit (Weight)
134g
Parent Unit (Weight)
92g
Charger (Weight)
41g
Baby Unit (Dimensions)
5.7 x 11 x 11.9 cm
Parent Unit (Dimensions)
4.5 x 6.6 x 9.4 cm
Charger (Dimensions)
3.8 x 8.6 x 6.9 cm
Country of manufacture
China
Resources
The following resources are available for the BT Baby Monitor 200
Customer reviews
Write a review for the BT Baby Monitor 200 here!
Excellent for Carers
Reviewed by Betty. Review Posted 01/12/2012
I use this Baby Mon itor for help in looking after my elderly mother. She can call me if she needs help getting out of bed or is feeling poorly. I can also tell instantly if she has had a fall. It gives both of us comfort that we are connected and can talk to each other even if we are in separate rooms. First Class piece of equipment.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Simply the best baby monitor ever used
Reviewed by James Giffen. Review Posted 27/05/2011
Excellent, does exactly what it needs to do. Great mic, sound and no interference, with wifi, bluetooth or dect phones
Range excellent.
  • Overall 5*
  • Ease of use 5*
Best Baby Monitor around
Reviewed by Deepa. Review Posted 28/03/2011
I spent some time researching and trying to find a good baby monitor, soon as I came across the BT Baby Monitor 200 I stopped looking, my baby loves the night light and music which helps her sleep, we also started to use the talkback feature which works well with the hi-definition sound quality. The design and colours fit well in the nursery and very light and easy to transport with the carry bag provided. I think this is a must have quality baby monitor which you can always trust.
  • Overall 5*
  • Ease of use 5*
  • Value for money 4*
Best Baby Monitor Around
Reviewed by Deepa Raithatha. Review Posted 28/03/2011
  • Overall 5*
  • Ease of use 5*
Great Baby Monitor
Reviewed by Rahul Nayar. Review Posted 28/03/2011
This is an amazing product, we previously had the BT 150 for our first baby, when we had our second baby we found the newer version online at it looks great and still easy to use. It comes with a small carry bag so when your visiting friends and family it is easy to pack.
The voice quality is crystal clear; I think this is the best baby monitor around at the moment.
  • Overall 5*
  • Ease of use 5*
Need advice
Reviewed by Jodie. Review Posted 02/01/2013
Just wondering if anyone has experienced the problems we have with their monitor. I think it is great and agree with what everyone has said about it. Easy to use,great sound etc. however have bought two now as the first handset went funny,letting out lots of beeping which couldn't be stopped. Now my second is doing the same??? Wondering if it just us being unlucky or if there is something we can do? Like I said,I love it otherwise but my son is only 15months so this could work out very expensive if I need to buy a new one again!
  • Overall 4*
  • Ease of use 5*
  • Value for money 2*
Great sound poor reliability
Reviewed by Mark. Review Posted 16/12/2012
This product us great when it works. Highly unreliable unit though. I have had 2 replacement units from BT and the 3rd one has just failed. First failed after 5 months and 2 units failed after 3 months. This is not what you expect from BT. Come on BT sort this out - or rather your supplier.
  • Overall 3*
  • Ease of use 5*
Persistent fault
Reviewed by Anonymous Review Posted 29/06/2012
I agree with all of the above comments regarding this monitor. Unfortunately after a couple of months the monitor developed a persistent fault which has rendered the unit useless. I have contacted BT on 2 occasions to report this issue but I have yet to receive a reply from anybody.
  • Overall 3*
  • Ease of use 5*
Virtually useless
Reviewed by K. Bridges. Review Posted 16/01/2012
Bought to replace old BT baby monitor which had served well for about 8 years. I have a son who is a nocturnal epileptic so needs to be monitored at night (His life may depend on it.)
The volume on maximum is so low that it can just be heard in my silent bedroom but is absolutely useless if watching TV or if there is any other noise, so have to have unit directly infront of me so I can watch the lights.
Contacted help desk and advised to reset unit but this made no difference what so ever, contacted them again and was told there was nothing they could do.
  • Overall 1*
  • Ease of use 1*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
