BT Baby Monitor 100
Customer rating
View reviews
Reasons to have BT Baby Monitor:
The BT Baby Monitor 100 also includes many great features such as DECT digital technology, polyphonic lullabies, rechargeable batteries and a flash light on the parent handset. High definition sound gives you a new level of sound quality - so real it sounds like your baby is in the room with you, sleek stylish design, not just practical and packed with features for your peace of mind, but with its sophisticated clean lines and styling it looks great in any room and you'll be eager to show it off!
Select any thumbnail below to view a larger image.
The following resources are available for the BT Baby Monitor 100
Write a review for the BT Baby Monitor 100 here!
We have had this monitor for 2 years now and have found it to be very reliable and love the way you can change the sensitivity. When our little one was tiny we had it on high sensitivity and volume but now she is 2 we have can have it low so we can only hear her when she is really upset. There has never been any interference unlike the analogue one we initially had.
I love this monitor!! however, the first two failed on the parent side and would not relay any sound until the volume button was pressed and that would last for about 2 seconds. therefore we tried other monitors and either experienced too much static noise or too bright for both parent and baby to sleep. so have decided to return to the bt model.
its very clear and easy to use, however, less then 2 months on and the sound has gone again. we are currently watching the monitor like hawks as the lights continue to work but still not sufficient as im sure you ll agree. please advice me. why does the same thing keep happening. three times now same problem but we like the wasy it works.. when it does!!
we found it very easy to set up but...that the only good bit about this product .after set up we turned it on when my daughter went to bed and we couldnt hear her ,so we went into her room and made a noise and still couldnt hear much so we shouted loud and could just pick it up.so for safety i think this product should not be being sold because if your baby was choaking you would not now till it was too late.i would love bt to contact me if different and could swap the unit to be like the one discribed (it sounds like the baby is in your room)in the discription about the product.
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
