Click to visit BT.com
BT Accord 30 Telephone Headset
BT BT Accord 30 Telephone Headset
Quicklinx: 4DCCWS00
Mfr#: 024336
£73.63 inc VAT
Customer rating
5.0*
View reviews
If you work from home, have a small business, are a large call centre or simply wish to free your hands when making calls, the BT Accord 30 is the ideal companion for your corded telephone or telephone system. It comes with a noise cancelling microphone (ideal if you work in a noisy environment) and a simple configuration module which will fit most types of corded telephones. It has a 6 position configuration switch for almost universal compatibility. You can easily switch between the headset and handset, and there is also a useful mute function. The BT Accord 30 has a comfortable 27mm ear cushion, and a neat quick disconnector which allows you to put your caller on hold while you disconnect your headset from your phone. Simply reconnect and continue your call.
High quality, affordable telephone headset with noise-cancelling microphone and amplifier. The BT Accord 30 noise cancelling telephone headset offers universal compatibility at a great price. Now everyone can have the benefits of a quality headset without breaking the bank or having to buy a new phone.
The supplied amplifier puts you in control and allows adjustment of volume, multimedia inputs, mute function, headset to handset function and the configuration switches. The BT Accord 30 can also be used as a multimedia headset.
Key features:
  • Noise cancelling microphone - ideal for noisy environments.
  • Amplifier included for increased functionality and control.
  • Use of a headset can reduce neck, upper back and shoulder tension.
  • Increases productivity by freeing your hands whilst on the phone.
  • Lightweight and comfortable.
  • Acoustic shock protection.
Amplifier features:
  • Switch between telephony and multimedia applications
  • Works with all PC sound cards and other audio devices.
  • Includes six position configuration switch to adapt to most direct-line and system phones. * Powerful stereo / mono output.
  • Automatic battery saving.
  • Operated by 2 x AA batteries or a AC adapter (not supplied).
  • Quick switch between headset and handset.
  • Mute function.
Contents
  • Telephone and multimedia amplifier.
  • Comfortable monaural (single ear) headset.
  • Comfortable ear cushion.
  • Full set-up and usage instructions.
  • Microphone foam piece.
  • Connection cables.
  • Microphone adjustment tool.
Image gallery
Select any thumbnail below to view a larger image.
Customer reviews read all 1 customer reviews
Write a review for the BT Accord 30 Telephone Headset here!
I saved £££s!
Reviewed by Anonymous Review Posted 03/02/2010
My Plantronics headset gave up recently I was not going to pay another £95 to replace it so I took a chance and when with a BT Accord. Glad I did - saved a packet and works perfectly, I can even attach it to my computer for Skype calls!
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
BT Accord 30 - headset - with amplifier
Headset - wired
Recommended Use
PC multimedia, corded phone
Headphones Type
Headphones - monaural
Headphones Form Factor
Semi-open
Wired
Sound Output Mode
Mono
Microphone
Boom
Bundled with
Amplifier
Headset
280 g
Recommended Use
Volume control, auto power save, Quick Disconnect
Bundled with
Amplifier
Headphones
Headphones Type
Semi-open
Headphones Technology
Dynamic
Wired
Sound Output Mode
Mono
Microphone
Boom
Headset cable - external - 1.55 m
2 x battery - AA type
Buy used stock
Ref Condition Packaging Accessories Manuals Software Functional
4DCC 1852  Used for brief period in original packaging.  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £40.03
All used stock has a 90 day warranty
Legend
  • Packaging Packaging
  • Accessories Accessories
  • Manuals Manuals
  • Software Software
  • Functional Functional
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
feature value
Recommended Use Corded phone
Recommended Use PC multimedia
Connectivity Wired
IP Telephony & Unified Comms [N/A]
Earcover Monaural
Brand BT
Stock Status Used Stock
Price Range Inc VAT 50 - 100
My BT Shop Basket
your basket is empty
Add an item by clicking
Mini basket dummy button. This button serves as indication only
next to the product of your choice.
BT Phone Offers
Recently viewed
Find an Easy to use phone
Check out our range of Which Best Buy Phones - Click Here
New BT Home Hub 3
BT Phone Finder
Brand new range of BT Baby Monitors
