The UMC 32" HD Ready TV features a slim line LED backlit design, glossy finish and integrated Freeview so you'll be able to save space by throwing away your digital set-top box, making it ideal for students or flatsharers.
Key Features:
The built-in USB enables you to play music and photos directly from your USB drive. This really allows your TV to be the hub for all your home entertainment - making your own photos and music even more enjoyable to watch. You'll be right at the heart of the action. You'll be able to play but not limited to:AVI, MPEG 1-4 , MP3, JPEG and BMP files.
An integrated Freeview tuner will allow you to watch all your favourite shows from over 80 TV and 20 radio stations across the country without the need for an additional set-top box.
Three HDMI inputs ensure you'll have enough ports to allow you to connect a couple of AV sources to your TV such as home cinema systems, games consoles, blu-ray players, set-top boxes or laptops. It'll allow you to switch between sources with a simple press of the remote too.
Its lightweight and slimline design ensures that you can easily move it from room to room and will create so much extra space when compared to older CRT models.
You can even use it as your PC monitor or attach your laptop to it. Just simply connect either a VGA or HDMI cable to your TV and you'll get to experience all your media via your TV. This TV is also wall-mountable.
32" LED TV (81cm visible screen size)
Built In Freeview
HD Ready 720P
Resolution 1366 x 768
7 Day TV Guide
Simple set up and auto tune
Power on/off
Nicam stereo sound
Teletext
Sleep Timer
Remote control (batteries included)
Standby less than 0.5 Watt
CI Slot to access subscription pay TV Channels
Inputs
3x HDMI
1x USB
1x Video/Composite
1x VGA/PC INPUT
1x Component (YPBPR) and Component (YPBPR)
1x 3.5 mm Jack for PC Audio input
1x pair RCA Audio shared for video
Output
1x COAX Audio Out
1x Headphone out
Vesa Wall Mounting 200x100
Weight 10.8Kg
Media File Ext. Codec
Video Audio
Movie .mpg Mpeg-1, Mpeg-2 MP3, WMA Max Resolution: 1920x1080
.avi Xvid, MJPEG, Max Data rate: 40Mbps
MPEG-4 SP/ASP
.ts Mpeg-2 Max Resolution: 1920x1080
.mov Mpeg-4 SP/ASP Max Data rate: 40Mbps
.mkv
.dat Mpeg-1
.mp4 Mpeg-1, Mpeg-2 Max Resolution: 1024x768
.vob Mpeg-2 Max Data rate: 40Mbps
Music .mp3 - MP3 Sample Rate 16K-48KHz
.wma - WMA Bit rate: 32K - 442Kbps
Picture .jpg Progressive JPEG Max Resolution: 1024x768
.jpeg Baseline JPEG Max Resolution: 8192x8192
.bmp BMP Max Resolution: 6500x6500
TV dimensions - 755(W) x 514(H) x 180(D)
