Click to visit BT.com
Best Value GeForce 8400GS 512MB
Best Value Best Value GeForce 8400GS 512MB
Quicklinx: 5LNDG600
Mfr#: R-VGA150853-P
The concept of Best Value is to offer customers the best value product, sourced from a variety of manufacturers all over the world, in any given category, at any point in time. The products selected for our Best Value range are carefully evaluated in terms of price, performance and manufacturing quality before they make it onto our website. Although certainly a 'value' brand, Best Value products are never inferior quality... just superb value for money.
Point of View GeForce (with CUDA) 8400 GS 512MB PCI-E x16 Dual-Link DVI-I/HDTV Graphics Card (Passive Cool)
Your search for the perfect graphics card is over -- SLI-Ready NVIDIA GeForce 8800 GT has arrived. The ideal combination of power, performance, and price, GeForce 8800 GT offers GeForce 8 Series goodness, 112 stream processors, and a 256-bit frame buffer for jealousy-inducing DirectX 10 gameplay at ultra fast frame rates. Compatible with the new PCI Express 2.0 bus architecture, offering a future-proofing bridge to tomorrow's most bandwidth-hungry games and 3D applications.
  • POV NVIDIA GeForce 8400 GS Graphics Card
  • 512MB GDDR2 600MHz Memory RAM
  • PCI Express x16
  • 1 x Dual-Link DVI-I - 1 x HDTV - 1 x VGA D-Sub
  • Microsoft DirectX 9.0/10.0 Supported
  • Shader Model 3.0/4.0 Supported
  • OpenGL 2.0 Supported
  • CUDA Enabled
GPU
  • Chipset nVidia GeForce 8400 GS
  • Chip Clock 450 MHz
  • Shader Clock 918 MHz
  • DAC Speed 400 MHz
  • HDTV Output Yes
  • Cooling System Passive
  • Memory (Maximum) 512 MB ( ) 600 MHz GDDR2
  • Memory Width 128 bit
Interfaces/Ports
  • Video Card Bus Type PCI Express x16
  • DVI Port 1 x DVI-I Dual Link
  • VGA Port 1 x 15-pin D-Sub
  • TV Out 1 x HDTV
System
  • Driver Support DirectX 10
  • Software Included Linux Drivers
  • System Requirements
  • Operating Systems Supported WHQL Certified - Windows 2000/XP/Vista - Linux
Physical
  • Form Factor Graphics Card
Graphics Processor
PCI Express x16
Digital Output
DisplayPort
Digital Visual Interface (DVI)
Memory Size
512
