Click to visit BT.com
Best Value Compact Adjustable LCD Monitor / TV Wall Mount
Best Value Best Value Compact Adjustable LCD Monitor / TV Wall Mount
Quicklinx: 502YWS00
Mfr#: EMX300
The concept of Best Value is to offer customers the best value product, sourced from a variety of manufacturers all over the world, in any given category, at any point in time. The products selected for our Best Value range are carefully evaluated in terms of price, performance and manufacturing quality before they make it onto our website. Although certainly a 'value' brand, Best Value products are never inferior quality... just superb value for money.
The stylish and extremely slim EMX300 provides 60 degrees of tilt and up to 180 degrees of angle left to right. Extends up to 370mm and folds to within 38mm from the wall. Supports LCD monitors and TVs up to 10 kg and is supplied with 75mm and 100mm VESA interface fittings. Supplied fully assembled for quick and simple installation. Complete with wall fixings. Finished in sliver.
  • Stylish, adjustable wall mount arm for LCD monitors and TV's
  • Ideal corner mount solution
  • Simple Installation
  • Extends to a full 380mm from the wall
  • Folds to within 38mm of the wall
  • All metal construction
  • Provides tilt and angle left to right movement
  • Supplied fully assembled
  • Compete with 75mm and 100mm VESA interface plates.
  • Supports up to 10 Kg's (approximately 20" LCD / LCD TV)
  • LCD / TV Size: 14" - 20"
  • Material: Steel
  • Finish: Silver
Image gallery
Select any thumbnail below to view a larger image.
ErgoMounts MX Series Compact Adjustable LCD Monitor / TV Wall Mount EMX300 - mounting component
Mounting component
Mounting Components
Wall arm
Recommended Use
LCD TV
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
10 kg
Material
Steel
Silver
Material
Steel
Silver
AV Furniture
Mounting component
Mounting Components
Wall arm
Recommended Use
LCD TV
Max Load Weight
10 kg
Angled, adjustable width, tilt
My BT Shop Basket
your basket is empty
Add an item by clicking
Mini basket dummy button. This button serves as indication only
next to the product of your choice.
BT Phone Offers
Recently viewed
Find an Easy to use phone
Check out our range of Which Best Buy Phones - Click Here
New BT Home Hub 3
BT Phone Finder
Brand new range of BT Baby Monitors
