Click to visit BT.com
BenQ MS500 2500 ANSI lumens SVGA DLP Projector
BenQ BenQ MS500 2500 ANSI lumens SVGA DLP Projector
1 Left In Stock
Quicklinx: 7QBBG600
Mfr#: 9H.J5277.13E
£238.80
Easy to Maintain, Easy on Your Budget
Long Lamp Life at up to 6000 hours Enjoy a lamp life performance of up to 6000 hours* - twice the lamp life expectancy of average projector lamps on the market! This certainly lowers the number of lamp changes and keeps all maintenance to a minimum.
*Lamp life results will vary depending on environmental conditions and usage.
Reliable Picture Quality with True-to-Life Color Performance
Reliable Picture Quality with True-to-Life Color Performance BenQ projectors that use DLP® technology are virtually immune to color decay - the yellow/green tint that some projector images develop over extended periods of usage. This is one technological advantage that you'll get to enjoy - year after year!
Filter-Free Design
BenQ DLP® projectors feature a filter-free design which could reduce the need for filter cleaning and filter replacement. This reduces the labour as well as the budget for filter maintenance and replacement.
Visual Excellence
2500 ANSI Lumens
A 2500 ANSI lumens projection lamp ensures great viewing even is location with low ambient light. The MS500 is ideal for small-sized meeting room with under 25 people
Sharpen up with high contrast ratios
The MS500 boasts high contrast ratio with 4000:1. High contract ratios translate to razor-sharp detail definition and a broader range of subtle color differences, which makes text is sharper, cleaner, and easy to read.
Go 3D with DLP® Link!
MS500 is equipped with 3D projection technology to bring you the same amazing 3D effects you get in 3D movies. Offered for no added cost, the 3D feature on 3D-ready BenQ projectors get your audience for an immersive real-life experience. All you have to do is add the 3D glasses, content and video card along with the MS500. A magical expedition is just to begin!
Thoughtful Features
Manual Vertical ±40°
With up to ±40° keystone adjustment, a perfect square is all you'll see. So go ahead and say goodbye to misshaped images, graphics, and charts!
Built-in Speaker
With the built-in 2W speaker of the MS500, not only you do you get a vivid visual performance, you get the same audio satisfaction, too!
feature value
Type DLP Projector
Brightness 2500ANSI lumens
Brand BenQ
Stock Status In Stock
Price Range Inc VAT 150 - 300
