Click to visit BT.com
Belkin VGA Home Theatre Cable 3.6m
Belkin Belkin VGA Home Theatre Cable 3.6m
Quicklinx: 5C7XG600
Mfr#: AV21401QP12
£11.19
The ideal solution for connecting computers to projectors, plasma TVs, LCD or CRT monitors, or flat-panel receivers, Super VGA provides true high-definition video, more accurate colors, and sharper detail from your components. Super VGA delivers true high-definition video by separating the signal into each of three primary colors. It carries full resolution of each color on its own wire to allow for exceptionally clear and bright images, exceeding the performance of Component, Composite, and S-Video. Composite and S-Video combine these signals together and then separate them at the monitor. Component separates colors in the video signal, but not to the extent of Super VGA.
Blue Series Super VGA Home Cinema Cables use the highest-quality materials to isolate your signal from interference and deliver the purest video solution available. Super VGA Home Cinema Cables are compatible with RGB and Component Video signal-processing standards.
Belkin Pure AV Blue Series Super VGA Home Theatre Cable - VGA cable - 3.7 m
VGA cable
Quad shielded coaxial
Cable Features
Molded , gold-plated connectors, ferrite bead
Length
3.7 m
Connector(s)
1 x 15 pin HD D-Sub (HD-15) - male
Connector(s) (Other Side)
VGA cable
Shielding Material
Foil with tinned copper braid
Cable Features
Length
3.7 m
Connector(s)
feature value
Type VGA
Length 3.7m
Brand Belkin
Price Range Inc VAT 0 - 50
