Click to visit BT.com
Belkin OmniView Soho Series 2-Port USB Dual Headed KVM
Belkin Belkin OmniView Soho Series 2-Port USB Dual Headed KVM
Usually dispatched within 3 working days
Quicklinx: 6KB9G600
Mfr#: F1DH102LEA
£131.92
The OmniView SOHO KVM Switch with Audio is engineered to give you control over multiple computers/servers from one console.
The SOHO KVM Switch is able to support video resolutions of up to 2048 x 1536, so you can use the latest in video display technology for all your computers.
With the firmware-upgrade feature, your investment in the KVM Switch is further ensured and its lifetime value is maximized. You don't have to change your KVM Switch to solve compatibility problems since you can solve them with easy firmware upgrades.
The SOHO KVM Switch features a built-in Hi-Speed USB 2.0 hub, so you can share two USB peripheral devices, such as a printer, with all your computers. There are two USB ports on the KVM Switch. One port is located on the back and the other is located on the front for easier access.
The SOHO KVM Switch allows you to share one set of speakers and one microphone with all your computers, so you won't need to unplug and reconnect your speakers and microphone every time you switch access from one computer to the next.
Direct-access port selectors, conveniently located on the front face of the SOHO KVM Switch, allow you to easily switch access from one computer to the next.
Image gallery
Select any thumbnail below to view a larger image.
Belkin OmniView SOHO Series 2 Port KVM Switch with Audio - KVM / audio / USB switch - 2 ports - desktop
KVM / audio / USB switch - 2 ports - USB
Enclosure Type
Desktop
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
Firmware upgradable, built-in 2 port Hi-Speed USB hub
DC 9 V
32 cm x 14 cm x 14 cm
0.68 kg
3 years warranty
Enclosure Type
Desktop
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2048 x 1536
Display / video : 4 x VGA - 15 pin HD D-Sub (HD-15) , Microphone : 2 x mini-phone 3.5mm , Headphones : 2 x mini-phone stereo 3.5 mm , Display / video : 2 x VGA - 15 pin HD D-Sub (HD-15) , Keyboard : 1 x 4 PIN USB Type A , Mouse : 1 x 4 PIN USB Type A , USB : 2 x 4 PIN USB Type A , Microphone : 1 x mini-phone 3.5mm , Headphones : 1 x mini-phone stereo 3.5 mm
Power adapter - external
DC 9 V
32 cm
14 cm
14 cm
0.68 kg
2 x USB cable kit - 1.8 m
3 years warranty
Service & Support Details
Limited warranty - 3 years
0 - 80%
feature value
Type KVM / audio / USB switch
Connectivity KVM
Ports 2
Brand Belkin
Price Range Inc VAT 100 - 150
