Click to visit BT.com
Belkin Gigabit Powerline HD Starter Kit up to 1000Mbps
Belkin Gigabit Powerline HD Starter Kit up to 1000Mbps Image for illustration only
Belkin Belkin Gigabit Powerline HD Starter Kit up to 1000Mbps
In stock now
Quicklinx: 6288WS
Mfr#: F5D4076UK
£89.99 inc vat
Create a multi-user HD home entertainment network through your electrical wiring. Imagine streaming flicker free HD movies, lag free gaming and more all at the same time. No need for special wiring, with Belkin's Gigabit Powerline HD networking adapters, it is that simple.
Powered by Gigle Semiconductor's mediaxtream chip, Belkin's Gigabit Powerline provides a secure, stable networking signal anywhere in the home - even for areas that are hard to reach by wireless connections.
Because of its high Gigabit speeds and consistent connection, Gigabit Powerline reduces online gaming latency and provides large bandwidth, making it ideal for online PC gaming and ultrafast high-quality transmission of multiple video streams delivering content at 1000Mbps of speed.
Create an even stronger network by adding a third or more Belkin Gigabit Powerline HD adapters to your set up. This enables the Xtendnet feature that provides more stability and better performance, essentially making the network "self-healing". The more adapters in your network, the more reliable the connection will get.
Setup of a powerline network is simple with its plug-and-play connectivity: plug one end of the adapter into an available wall socket. Connect the other end to any device with an available Ethernet port (RJ45), such as a gaming console, set-top box, or computer.
Belkin Gigabit Powerline HD Starter Kit - bridge
Bridge
External
United Kingdom
Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV)
128-bit encryption
IEEE 802.3, IEEE 802.3u, HomePlug AV
Apple MacOS X, Microsoft Windows Vista / 2000 / XP
Bridge
External
United Kingdom
Wired
128-bit encryption
1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x network / power - HomePlug AV
Encryption Algorithm
128-bit AES
Power supply - internal
Software Included
Drivers & Utilities
Service & Support Details
Limited warranty - lifetime
10 - 85%
feature value
Type Bridge
Wired / Wireless Wired
Speed 1Gbps
Protocol Ethernet
Protocol Fast Ethernet
Protocol Gigabit Ethernet
Protocol HomePlug AV (HPAV)
Connection Type Homeplug/Powerline
Form Factor External
Brand Belkin
Stock Status In Stock
Price Range Inc VAT 50 - 100
