Image for illustration only
Belkin Gigabit Desktop Network PCI Card
The Belkin Gigabit Desktop Network PCI Card lets you easily upgrade your desktop computer to full gigabit speeds. It's backward-compatible with your existing 10/100 network, allowing you to simply insert the Card into your computer and instantly provide your high-performance workstation with the speed to quickly transfer large video, audio, and graphic files throughout the network.
It's so simple to install, you'll be moving files throughout your network within minutes. The Belkin Gigabit Desktop Network PCI Card auto-negotiates between a 10Mbps, 100Mbps, or 1000Mbps network and automatically adjusts for straight-through or crossover cables - you don't have to worry about cable type.
Compatible with all existing 10/100 networks and major operating systems, your Gigabit Desktop Network PCI Card from Belkin delivers your files with maximum speed, reliability, and efficiency.
