Click to visit BT.com
Belkin Cat6 UTP Snagless Patch Cable White 2m
Belkin Belkin Cat6 UTP Snagless Patch Cable White 2m
Quicklinx: 2313G600
Mfr#: A3L980B02M-WHTS
£4.52
How does a Cat 6 patch cable affect your network? It's like when you replace one blocked pipe in your plumbing line and suddenly the flow increases, the transfer is more fluid and the whole system is improved.
The RJ45 High Performance Category 6 UTP Patch Cable is the perfect performance upgrade. This cable is used to replace any Cat 5 cable that fails to support 100 Base-T or Gigabit Ethernet. It comes with RJ45 male-to-male connectors and a snagless molded strain relief.
PRODUCT FEATURES:
Perfect in conjunction with 100 Base-T and Gigabit Ethernet networks;
50 micron gold plated connectors to ensure a clean and clear transmission;
Snagless molds protect the RJ45 tap from being damaged during installation;
Capable of improving the return loss in your current network by 40%;
Exceeds the performance requirement of Category 6;
PowerSum tested;
Internal load bar assures accurate positioning of pairs and consistent high performance.
Image gallery
Select any thumbnail below to view a larger image.
Belkin High Performance patch cable - 2 m
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568A
Molded, snagless , gold-plated connectors
Length
2 m
Connector(s)
1 x RJ-45 - male
Connector(s) (Other Side)
1 x RJ-45 - male
White
Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch; OmniView SMB CAT5 KVM Switch
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568A
Length
2 m
White
Connector(s)
1 x RJ-45 - male
1 x RJ-45 - male
Belkin Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch , Belkin OmniView SMB CAT5 KVM Switch
feature value
Length 2m
Colour White
Brand Belkin
Price Range Inc VAT 0 - 50
