Click to visit BT.com
Belkin Cat6 UTP Snagless Patch Cable Blue 1m
Belkin Belkin Cat6 UTP Snagless Patch Cable Blue 1m
10 In stock
Quicklinx: 18KKG600
Mfr#: A3L980B01M-BLUS
£3.19
How does a Cat 6 patch cable affect your network? It's like when you replace one blocked pipe in your plumbing line and suddenly the flow increases, the transfer is more fluid and the whole system is improved.
The RJ45 High Performance Category 6 UTP Patch Cable is the perfect performance upgrade. It is used to replace any Cat 5 cable that fails to support 100 Base-T or Gigabit Ethernet and comes with RJ45 male-to-male connectors and a snagless molded strain relief.
PRODUCT FEATURES:
Perfect in conjunction with 100 Base-T and Gigabit Ethernet networks;
50 micron gold plated connectors to ensure a clean and clear transmission;
Snagless molds protect the RJ45 tap from being damaged during installation;
Capable of improving the return loss in your current network by 40%;
Exceeds the performance requirement of Category 6;
PowerSum tested;
Internal load bar assures accurate positioning of pairs and consistent high performance;
2-row staggered pin configuration to control cross-talk at hyper-frequency.
Image gallery
Select any thumbnail below to view a larger image.
Belkin High Performance patch cable - 1 m
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Molded, snagless , gold-plated connectors, staggered pin configuration
Length
1 m
Connector(s)
1 x RJ-45 - male
Connector(s) (Other Side)
1 x RJ-45 - male
Blue
Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch; OmniView SMB CAT5 KVM Switch
Network Cable Type
Patch cable - CAT 6
Length
1 m
Blue
Connector(s)
1 x RJ-45 - male
1 x RJ-45 - male
Belkin Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch , Belkin OmniView SMB CAT5 KVM Switch
feature value
Length 1m
Colour Blue
Brand Belkin
Stock Status In Stock
Price Range Inc VAT 0 - 50
