Click to visit BT.com
Avocent 1x16 Port KVM With IP Console Port PS2/USB
Avocent Avocent 1x16 Port KVM With IP Console Port PS2/USB
Usually dispatched within 3 working days
Quicklinx: 6KJ7G600
Mfr#: AV3016-201
£745.72
The Avocent AutoView digital KVM 3016 appliances include access for one digital user and access for a local user in a single solution. The on-board web interface lets you remotely and securely manage all connected servers and serial-based devices from any location. The local port gives you convenient at-the-rack access. These solutions also include local PS/2 and USB peripheral support.
The AutoView digital KVM appliance offers LDAP user authentication, SSL-128 bit, DES, 3DES or AES communication, which are superior to industry standards. Other security features include 64 user accounts and an access control list for each user.
Avocent AutoView 3016 - KVM switch - 16 ports - desktop
KVM switch - 16 ports - Sun, PS/2, USB - CAT5
Enclosure Type
Desktop - 1U
Ports
16 x KVM port(s)
KVM Users Qty
1 local user , 1 IP user
128-bit encryption, LDAP support, IPv6 support
AC 120/230 V ( 50/60 Hz )
43.2 cm x 20.3 cm x 4.5 cm
3.6 kg
United Kingdom
2 years warranty
Enclosure Type
Desktop - 1U
Ports
16 x KVM port(s)
KVM Local Users Qty
1 local user
KVM IP Users Qty
1 IP user
Server Connection Via Twisted Pair
CAT5
Keyboard / Mouse Interface
Sun, PS/2, USB
Encryption Algorithm
DES, Triple DES, AES, SSL
Max Resolution
1600 x 1200 @ 75 Hz
128-bit encryption, LDAP support, IPv6 support , server connection via twisted pair
Keyboard / mouse / video / serial : 16 x RJ-45 , 1 x RS-232 - 9 pin D-Sub (DB-9) - management , Display / video : 1 x VGA - 15 pin HD D-Sub (HD-15) , Keyboard : 1 x generic - 6 pin mini-DIN (PS/2 style) , Mouse : 1 x generic - 6 pin mini-DIN (PS/2 style) , USB : 2 x 4 PIN USB Type A , 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Power supply - internal
40 Watt
43.2 cm
20.3 cm
4.5 cm
3.6 kg
Rack Mounting Kit
Included
CE, UL, VCCI, C-Tick, GOST, cUL, GS, MIC, FCC, IRAM, ICES, 128 bit SSL
United Kingdom
2 years warranty
Service & Support Details
10 °C
50 °C
feature value
Type KVM switch
Connectivity KVM
Ports 16
Brand Avocent
Price Range Inc VAT 500 - 750
