Asus USB-N10 150Mbps 802.11n USB Wireless Adapter, Compact and Powerful antenna
Customer rating
View reviews
The ASUS USB-N10 provides superior wireless performance for your PC compared to legacy wireless 802.11g technology. It uses a best-in-class MIFA antenna to deliver consistent HD quality data streaming and a much wider wireless operating range. In addition to providing better bandwidth and coverage, the 802.11n standard it's also backward compatible with 11g and 11b networks, ensuring existing networking hardware can be fully utilized.
The wireless USB adapter incorporates an impressive MIFA antenna which is better than PCB and Chip antennas widely used in generic adapters. This integrated antenna and connector design provides a compact form factor that is much smaller than conventional adapters and greatly expands the transmission range.
USB-N10 is the smallest wireless USB adapter in the world. Boasting a 3 cm body length, it is easy to carry and takes up little space when attached to a notebook. Compared to most USB Wi-Fi adapters, it is extremely compact and sturdy with its pocket-sized format and strong plug-in design. This small size and strengthened one-piece shape allows a host notebook to be connected to the USB-N10 even when it is placed in a slim carrying case or bag. Thus you can enjoy constant connectivity with the ASUS USB-N10!
The USB-N10 delivers PSP Xlink connection support. You can play system-link games over the Internet rather than just over your LAN while on-the-move.
Select any thumbnail below to view a larger image.
Write a review for the Asus USB-N10 150Mbps 802.11n USB Wireless Adapter, Compact and Powerful antenna here!
If only just ordered the product
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
