Click to visit BT.com
Asus P7P55D, Intel P55, 1156, 4DDR3, 2PCI-Ex16, 16x4x, RAID, 8CHHD, ATX, GB LAN
Asus Asus P7P55D, Intel P55, 1156, 4DDR3, 2PCI-Ex16, 16x4x, RAID, 8CHHD, ATX, GB LAN
Quicklinx: 64KNG600
Mfr#: P7P55D
This motherboard supports the latest Intel Lynnfield processors in LGA1156 package which has memory and PCI Express controller integrated to support 2-channel (4 DIMMs) DDR3 memory and 16 PCI Express 2.0 lanes providing great graphics performance. Intel Lynnfield processor is one of the most powerful and energy efficient CPU in the world.
This motherboard supports the latest PCIe 2.0 devices for double speed and bandwidth which enhances system performance.
Image gallery
Select any thumbnail below to view a larger image.
ASUS P7P55D - motherboard - ATX - LGA1156 Socket - P55
Motherboard - ATX
Chipset Type
Intel P55 Express
Processor Socket
1 x LGA1156 Socket
Compatible Processors
Core i5, Core i7
Max Supported Memory
16 GB
RAM Supported
4 DIMM slots - DDR3 SDRAM , non-ECC , unbuffered
Storage Ports
1 x ATA, 7 x SATA, 1 x eSATA
USB Ports Configuration
14 x USB
FireWire Ports Configuration
2 x FireWire
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Motherboard - ATX
Chipset Type
Intel P55 Express
Processor Socket
LGA1156 Socket
Max Processors Qty
1
Core i5, Core i7
16 GB
Supported RAM Technology
DDR3 SDRAM
Supported RAM Speed
1600 MHz, 1333 MHz, 1066 MHz
Supported RAM Integrity Check
Non-ECC
Supported RAM (Registered or Buffered)
Unbuffered
RAM Features
Dual channel memory architecture
Audio
Audio Codec
VIA VT1828S
DTS Surround Sensation UltraPC, High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slot(s)
1 x processor - LGA1156 Socket , 4 x memory - DIMM 240-pin , 1 x PCI Express 2.0 x16 , 1 x PCI Express 2.0 x16 ( x4 mode ) , 2 x PCI Express 2.0 x1 , 3 x PCI ( 3.3 V/ 5 V )
Storage Interfaces
Serial ATA-300 - connector(s): 6 x 7pin Serial ATA - 6 Device(s) - RAID 0 / RAID 1 / RAID 10 / RAID 5 , JMicron JMB363 : Serial ATA-300 - connector(s): 1 x 7pin Serial ATA - 1 Device(s) , JMicron JMB363 : ATA-133 - connector(s): 1 x 40pin IDC - 2 Device(s) , JMicron JMB363 : Serial ATA-300 - connector(s): 1 x 7pin external SATA - 1 Device(s)
RAID Features
Intel Matrix RAID Technology
1 x audio - line-In - 4 PIN MPC , 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style) , 1 x mouse - generic - 6 pin mini-DIN (PS/2 style) , 8 x Hi-Speed USB - 4 PIN USB Type A , 1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x audio - line-out - mini-phone stereo 3.5 mm , 1 x audio - line-In - mini-phone stereo 3.5 mm , 1 x microphone - output - mini-phone 3.5mm , 1 x audio - line-out (side surround) - mini-phone stereo 3.5 mm , 1 x audio - line-out (rear) - mini-phone stereo 3.5 mm , 1 x audio - line-out (centre/subwoofer) - mini-phone 3.5mm , 1 x audio - SPDIF output - TOSLINK , 1 x IEEE 1394 (FireWire) - 6 PIN FireWire
Additional Connectors (Optional)
1 x IEEE 1394 (FireWire), 6 x Hi-Speed USB
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS EZ Flash 2, ASUS O.C. Profile, ACPI 2.0a support, SMBIOS 2.5 support
Manual Settings
CPU frequency, processor core voltage, memory voltage, PCI Express x16 slot frequency, chipset voltage
Sleep / Wake Up
Wake on LAN (WOL), wake on ring (WOR)
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, MemOK!, heat pipe chipset cooling, ASUS Turbo Key, ASUS Q-Design, Stack Cool 3, T.Probe, 12+2 Phase Power Design, CrashFree BIOS 3, ASUS Q-Connector, ASUS AI NET2, ASUS Noise Filter, ASUS Stepless Frequency Selection (SFS), audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, ASUS Precision Tweaker 2, Intel Extreme Memory Profile (XMP) support, ASUS Express Gate, ASUS Fan Xpert, ASUS TurboV, Intel Turbo Boost Technology, AMD CrossFireX technology support
1 x IDE cable , 4 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS Live Update
Plug and Play, ACPI 2.0
30.5 cm
24.4 cm
