Asus 27" ROG Swift PG278Q 27" G-Sync 144Hz Gaming Widescreen LED
FORGED FOR GAMING PERFECTION: THE WORLD'S FIRST WQHD G-SYNC MONITOR!!!
Key features
  • WQHD G-SYNC fast gaming monitor
  • ASUS-exclusive gameplay features and advanced connectivity
  • ROG-inspired, ergonomic design
Product codes
chevron icon
chevron icon
Quite possibly the best gaming monitor ever made and ideally suited to NVIDIA cards with 3D Vision 2.0 and G-Sync technology. This monitor runs at a staggoring 2560x1440 resolution with 144Hz technology and a 1ms response, even better this is the latest in TN technology.
- Display: 27-inch (16:9) wide screen
- Resolution: 2560 × 1440 WQHD with 1ms response rate.
- 144Hz max refresh rate for fast gaming.
- Brightness: 350cd/m²
- Connectivity: DisplayPort, USB 3.0 ports (upstream x 1, downstream × 2)
- Ergonomic Tilt (+20° ~ -5°), swivel (+60° ~ -60°), pivot (90° clockwise), height adjustment (0 ~ 120mm)
- VESA wall mountable (100 × 100mm)
- ASUS Exclusive
- ASUS GamePlus
- 5-way menu controller,
- Minimum bezel, Maximum ROG design!
- Narrow 6mm bezel designed for multi-monitor setups
- Pixel Pitch: 0.233mm
- Display Colors: 16.7M
- Refresh Rate: Over 120 Hz
- Response Time: 1ms (GTG)
- Special ASUS Features: GamePlus and 5-way joystick OSD navigation
Experience Immersive Gaming and Outstanding Visuals
Say goodbye to motion blur and lag with 120+ Hz refresh rate and 1ms response times for a competitive advantage in all your games thanks to smoother gameplay and on-screen responsiveness. The ROG SWIFT PG278Q also features GamePlus, an exclusive ASUS feature. GamePlus is an OSD overlay that enables crosshair and timer functions to be displayed on the monitor. Gamers can select from four different crosshair types to suit the gaming environment, while the timer function allows players to track elapsed time in real-time strategy games. These tools allow gamers to practice and improve their gaming skills. The ROG SWIFT PG278Q provides an array of options that include DisplayPort 1.2 for native WQHD output, dual USB 3.0 ports, VESA wall mount capability and a versatile stand with full tilt, swivel, pivot, and height adjustment for an ideal viewing position while playing the latest game title. The smart cable management feature rids your desktop of tangled wires, while the super narrow 6mm bezel ensures the ROG SWIFT PG278Q is an ideal choice for seamless multi-display gaming setups. Another nod to gamers and improving the user experience is a 5-way joystick that allows the user to easily navigate the OSD and make quick monitor adjustments. The World's First and Fastest WQHD Monitor powered by NVIDIA G-SYNC The ROG SWIFT PG278Q is also the world's first WQHD monitor powered by NVIDIA® G-SYNC™ technology. NVIDIA® G-SYNC™, a breakthrough in display technology, synchronizes the display's refresh rates to the GPU. The ROG SWIFT PG278Q eliminates screen tearing, minimizes stutter and input lag to deliver the smoothest gaming experience possible. With G-SYNC™ technology objects look sharper and more vibrant, while gameplay is more fluid and responsive.
chevron icon
Product Description ASUS ROG SWIFT PG278Q - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class C
Energy Consumption per Year 64 kWh
Power Consumption (On mode) 44 W
Features USB 3.0 hub
Native Resolution QHD 2560 x 1440 at 144 Hz
Pixel Pitch 0.233 mm
Brightness 350 cd/m²
Contrast Ratio 100000000:1 (dynamic)
Response Time 1 ms (grey-to-grey)
Gaming Yes
Colour Support 16.7 million colours
Input Connectors DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black
Dimensions (WxDxH) - with stand 61.97 cm x 6.598 cm x 36.296 cm
Weight 7 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, PSE Mark, J-MOSS, ErP Ready, CEL level 1
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
