Click to visit BT.com
Arena 3U 32TB SAS Host RAID System
Quicklinx: 6C69WS00
Mfr#: SS-6652E/32TB
£7,993.30 inc VAT
The SS-6652E is a single controller, SAS to SAS RAID storage subsystem. In a compact 3U - 16 bay chassis, featuring hot-swappable power supplies and fans. The RAID controller, fans, and power supplies are modularized allowing for easy removal from the rear of the unit. It also features a web-based GUI allowing easy remote configuration and monitoring using a web browser.
Another feature to the SS-6652E is an expansion port that enables JBOD expansion unit to be attached and increase the total storage capacity without the cost of another independent RAID subsystem. The JBOD expansion feature can reduce the total cost of ownership of an Arena Maxtronic storage solution.
Arena SS-6652E - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 3U
Total Array Capacity
32 TB
Serial Attached SCSI
Host Channels
2
16 (installed) / 16 (max)
Supported Drives
Serial ATA-300
48.5 cm x 56.5 cm x 13.2 cm
24 kg
Built-in Devices
Status LCD
Storage Controller
RAID ( Serial ATA-300 ) - RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 60
Hard Drive
16 x 2 TB hot-swap
AC 120/230 V ( 50/60 Hz )
Power Redundancy
3 years warranty
Hard drive array
Enclosure Type
Rack-mountable - 3U
48.5 cm
56.5 cm
13.2 cm
24 kg
Chassis
Built-in Devices
Status LCD
16
Supported Devices / Modules Qty
16
Supported Drives
Serial ATA-300
Storage
32 TB
HDD Array External Interface
Host Channels
2
PowerPC 440SP
Storage Controller
RAID - integrated ( Serial Attached SCSI )
Controller Interface Type
Serial ATA-300
Data Transfer Rate
300 MBps
Cache / Buffer Size ( Max )
1 GB (installed) / 4 GB (max)
Supported Devices
Hard drive, disk array (RAID)
RAID Level
RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 60
Hard Drive
Hot-swap - plug-in module
16 x 2 TB
Expansion Bays
16 (total) / 0 (free) x hot-swap - 3.5"
2 x Serial Attached SCSI
Mounting Kit
Included
CE, UL, C-Tick, BSMI, cUL, CB, FCC
2 x power supply - hot-plug / redundant - plug-in module
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
460 Watt
3 years warranty
Service & Support Details
Limited warranty - 3 years
5 °C
20 - 80%
feature value
Type Hard drive array
Controller Type RAID
Brand Arena
Price Range Inc VAT 1500+
My BT Shop Basket
your basket is empty
Add an item by clicking
Mini basket dummy button. This button serves as indication only
next to the product of your choice.
BT Phone Offers
Recently viewed
Find an Easy to use phone
Check out our range of Which Best Buy Phones - Click Here
New BT Home Hub 3
BT Phone Finder
Brand new range of BT Baby Monitors
